Question about Radio Flyer Steer and Stroll Deluxe Trike
Need replacement parts for Radio Flyer Steer&Stroll Deluxe Trike
I need to replace the push bar and the steering mechanism-where do I find the parts?
    Problem Solver:
Try calling Radio Flyer's Customer service for replacement parts at 1(800)621-7613
Posted on Jun 20, 2009
I need to replace the front wheel/pedal assembly on a Radio Flyer Model 21. What is the price & availability?
Mike Mandish
msimonsez@aol.com
Posted on Aug 05, 2009
3 Suggested Answers
  • 3 Answers
SOURCE: radio flyer steer & stroll won't steer
add a little grease
Posted on Jun 16, 2009
  • 123 Answers
SOURCE: where can i find a copy of the assembly
You can download instructions here: MANUAL
Posted on Jan 20, 2011
Power steering fluid drained out all at once. Hose is good. Mechanic says power steering rack is cracked. How much to fix.
The parts that need to be replaced is the whole power steering component that actually turn the wheels.Don't let him temp repair it...that's a waste of money. Make sure there is a wheel alignment done after the parts are replaced
Feb 14, 2018 | 1996 Nissan Altima
My mazda bongo friendee ignition is turning freely had to remove battery leads to turn off and can not turn on now
Yeah,no push start on automatics after 1960.No front pump in trans.May have been 1958.Anyway,if the key is stuck in the switch because it won turn back,there's a rod connecting the switch that push/pulls the position bar inside the box mounted on the steering column under dash.Remove said box(a bolt in each end,probably a 8mm or 5/16ths socket) and lift it off the end of the rod.You can then use a small pin punch to move the bar to start the vehicle and drive it to the shop.Since the switch is turned on anyway,the steering wheel will not lock.Drivable.
Oct 12, 2012 | Mazda Vehicle Parts & Accessories
Looking for part for Craftsman Lawn Tractor
go to Sears Parts direct.com punch make model they will answer your question and can get a parts list.
May 17, 2017 | Craftsman Garden
What is power steering and how much to fix it
Power steering the mechanical/Hydraulic assist to make the cars steering wheel turn easily by using a hydraulic pressure pump to activate a valve that helps to push the wheel in the direction you desire to turn. As far as cost to repair, it varies by what particular part of the Power Steering is defective, in most cases that is the part called the steering rack, and that's about $1000. to replace and re-align the front end after the repair.
Feb 22, 2011 | 2001 Ford Windstar
1992 Olds cutlass ciera s V6 3.3 won't start. Starter and battery working properly and tried to putting car in neutral and nothing happens. any ideas to try next?
You need to test your mechanical ignition switch located on top of the steering column by your feet. Remove bottom panel below steering column then 2 or 4 nuts holding column to dash. Lower steering column - the rectangular component with the metal rod going in the back side ( goes toward the steering wheel ) is the mechanical ignition switch. Disconnect and inspect harness for corrosion and dirty contacts.If the contacts are clean ( not green, white, or burnt) then look closely at the mounting screws to see if there are marks from where they were originally mounted - it is possible the switch moved away from the steering wheel which would keep that metal bar from activating the start circuit. If the switch moved, loosen mount screws and move switch back to original spot. If the switch didn't move then you can try starting the car with the key and moving that metal arm manually, pushing it toward the engine to activate start circuit. The switch MUST be mounted to the steering column for the circuit to be open ( complete) as the ground is supplied through the mount screws. If this still doesn't work then replace the switch.
Good luck!!
Nov 27, 2010 | 1992 Oldsmobile Cutlass Ciera
Symptoms: rattling noise coming from front end of 98 explorer, pulls at the least little bumps, eats up front tires like crazy. Doesn't feel safe driving. What I've been told already: upper and lower...
definitely sounds like a ball joint problem, bushings would not cause it to chew up tires a worn moving mechanical part would such as steering components,wheel bearings,ball joints, and believe it or not shock absorbers
Jul 22, 2017 | 1998 Ford Explorer
Quinny buzz handle won't extend and frame has started to collapse unexpectedly while baby in push chair
Sounds like the handle bar extender mechanism has broken internally and the Gas strut is faulty. This happened to mine. Both parts are readily available from Dorel UK 01842 763 281 (Mon – Fri, 8:30 am to 4:30 pm). They are the sole supplier of parts for Quinny. However, the Gas Strut is a pressurised mechanism and has to be replaced by Dorel. You will need to speak with them and arrange for the frame of the buggy to be sent to them (at your cost if out of warranty) and they will replace whatever parts you need plus do a full service.
Feb 07, 2010 | Quinny Buzz Three Wheel Stroller
I hit and broke the 'handle bar,' (wrong name for
The local dealer for this is the sure bet.Get in touch with the parts section at the dealer.Your local autoparts store has items such as brake pads and hard mechanical parts but not multifunction switches and electronics.I hope I could help.Get back to me with any questions.
Dec 22, 2009 | 2003 Pontiac Grand Am
Radio Flyer Steer and Stroll Deluxe Trike Logo
3,356 people viewed this question
Top Radio Flyer Toys Experts
Tom Chichester
erex 01
erex 01
obsteiner
Are you a Radio Flyer Toy Expert? Answer questions, earn points and help others
