Question about Bernina Virtuosa 160
How to raise your feed dog for my bernina 807?
  • 8 Answers
SOURCE: I have a Bernina Aurora
If you remove the metal plate on the bottom of your machine, you can see the workings of the feed dog raise and lower button. With some luck it just might be a screw that came out or it might be a broken spring inside the sewing arm.
Without a service manual or a view of what it should look like inside when it is functioning correctly, at best you would just be guessing. It should be a simple 5 min fix but it is best to take it to a Bernina dealer for proper repair. Good luck, bushvideo
Posted on Sep 27, 2008
RickE1
  • 202 Answers
SOURCE: Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
Posted on Feb 07, 2009
SOURCE: I am looking for an instruction manual
Can any please tell me where I can purchase a manual for a Bernina Artista 200 Manual as I accidently threw my away.
Regards Cathy
Posted on Feb 15, 2009
SOURCE: Is there a way to lower the feed dogs ''a little''?
I thought this was free . . . didn't know I'd be asking to join. So, I called the shop where I purchased the machine. They were able to help me fix the problem.
Posted on Nov 13, 2009
  • 1116 Answers
SOURCE: feed dogs won't work
Take your machine to an authorized Bernina dealer for service.
Proper service and care will ensure the value of the machine.
This brand holds it's value better than any other brand and always resells for good prices on Ebay.
You can check the Bernina website for dealers in your area.
Posted on May 07, 2010
Bernina 1230 manual- How do you raise the feed dogs?
Perhaps the manual for the 1260 will help (pg 5, item 18):
BERNINA Sewing Systems
Sep 05, 2017 | Bernina Sewing Machines
How do I lower and raise dogs on the bernina 1008
unless there is a mechanical failure , the feed dogs are governed by the forward/reverse control
if it is in neutral position then the dogs will not move
Oct 27, 2015 | Bernina Sewing Machines
My Bernina 930 does not feed the fabric through the feed dogs. Hoe do I fix this?
Did you unknowingly drop the feed dogs, as for darning? It is the lowest knob on the right, the silver dial in the center raises and lowers the feed dogs.
Feb 27, 2015 | Bernina Sewing Machines
Adjust dog feed
The feed dogs in all Classic Bernina machines from the 130-180\'s will eventually come out of adjustment. This is due to the so-called cost savings modern manufacturing method of drilling holes in the machine frame parts and using thread forming screws instead of tapping or cutting cylindrical threads and the use of standard fasteners.
Regarding the screw fastener itself having a cylindrical screw form, the Bernina Classic machines used thread forming screws. Not necessarily a bad thing but in this case a dumb idea. Because these screws are not exactly cylindrical, they will not hold tight over time, hence loosening of the feed dog\'s height adjustment. You will need a T-10 Torx screw driver to make the adjustment.
Proceed by opening the bobbin cover door. You will find a rectangular opening to your upper right and will be able to see the screw head of the feed dog adjustment. With the feed dog in the upper most raised position, loosen the screw and lift the feed dog. Tighten the screw.
Check the height of the feed dog by rotating the hand-wheel in the direction of motion until the needle eye is flush with the needle plate. The feed dog teeth will also be flush in the normal position. If too high or too low, readjust to this height and, voila\'..... SewTechnical Home
Jul 15, 2014 | Bernina Artista 180
Bernina feed dog down and will not return to normal position by switch
1. Clean and lubricate entire machine following the MANUAL instructions.
2. Try to "lower" it again then try to raise it - several times.
If this does not solve it, see a service person.
Jul 08, 2014 | Bernina 1008
How do I use the button hole foot on the Bernina 807 minimatic?
There isn't an automatic button hole on this machine. You can do it manually. Thread the bobbin thread as usual, but put it through the little hole on the hook in the bobbin case. Set the stitch length between 0 and 1, like a nice satin stich. Set the needle position to the far left and the stitch width to 2. Sew down the left side. Center the needle, set the width to 4 and lower the feed dogs, stitch about 6 stitches across the bottom. Then reverse the direction, set the needle to the right, stitch width to 2 and go back up the right side. Lower the feed dogs again, set a wide stitch and finish the top.
Another good option is to buy a universal presser foot shank from Bernina and then attach an old cam type buttonhole attachment from Singer. They make beautiful buttonholes and you can even do a keyhole button hole.
Jun 29, 2010 | Bernina Activa 130
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
Sewing Machines Logo
66 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
