Question about Sony Bravia KDL-37V4000 37 in. LCD TV
Picture settings for sony bravia kdl37v4000 37 inch
ramon49
  • 111 Answers
SOURCE: Sony Bravia 52 inch - Picture and Picture:
you need to feed 2 signals in to the set.
Posted on Apr 08, 2009
welcomejee
  • 10594 Answers
SOURCE: i have a sony bravia xbr 32 inch and the picture
It is possible that Twin Picture function is enabled, turn it off with remote/ menu options.
If this is not the case then T-Con board sounds bad and needs to be tested/ replaced.
Qualified tv tech will test and replace it.
Thanks.
Posted on Oct 06, 2009
Kensolutions
  • 455 Answers
SOURCE: standby light blinks 6 times..no picture...i have
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Aug 20, 2011
SD Tech
  • 14553 Answers
SOURCE: Sony 55 inch Bravia Engine 2. Occasionally pictur
you MAY have a problem related to the HDMI and to prove or disprove it I would connect Component if you can.
Posted on Mar 20, 2012
  • 517 Answers
SOURCE: 37 inch sony bravia color problem
try to play first dvd on you tv on test if the tv has a problem or on just on you digital/analog antenna..
If the problem is still there when you play dvd the possible prob is T-con board..
hope it helps..please rate..
Posted on Apr 28, 2012
Hi I have the 42 inch Sony Bravia in my bedroom.The picture upstairs in the bedroom is too big for the tv if that makes sense.
Hello. It's not a picture setting, it's a format, or picture size setting. Look for a button on the remote labeled Format, or Size, or Zoom, or something similar. You want to select 16:9, or Full, or whatever fills the screen without zooming.
Oct 14, 2015 | Sony Televison & Video
Blurry picture on new 40 inch.
picture quality is still based on the source you are playing.. try a 720p or 1080p source.. make the picture setting vivid
if its still blurry please call an authorized sony service center near you... check for the number on the sony site for your country
Aug 17, 2014 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA XBR KDL-46XBR4 HDTV LCD Television
you need to replace defective capacitors in the power supply of the tv
Jan 05, 2013 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
Sony bravia screen just stays on black and wont go to picture.
It sounds like a main board failure but could be a power supply issue as well. The set will need to be diagnosed
Oct 01, 2012 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
I have a sony bravia xbr 32 inch and the picture is only on half the screen
Thanks.
Oct 06, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a sony bravia 50 inch rear projection tv. model KDFE50A12U .It has been working fine with no hints of a problem,yesterday when i switched it on the power light started to flash and the fan,bulb and...
i have a sony bravia 50 inch rear projection tv kdf 50e2000 the problem is it fail to switch on when it did it swicth on had black line cross the screen
Apr 01, 2009 | Sony Televison & Video
Tuning problem
The tuner is bad. Could also be the video process, since the hi-def is decoded there
Oct 06, 2008 | Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
Moved Sony Bravia TV, now will not turn on at all
The warranty on this set should be for 1 year. Return it for warranty service. Unless the set was dropped, moving it should not have effected anything. DO NOT open the set sas that would void the warranty.
Dan
Jun 11, 2008 | Sony BRAVIA KDL52XBR2 Television
Sony Bravia KDL-37V4000 37 in. LCD TV Logo
21 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
