Question about SanDisk Sansa e260 MP3 Player
Pandigital frame - the rermote does not work, near or across the room.
This is new as of today. Why is the remote not working? It came with a battery in it and I removed the plastic that was there.
I have a pandigital photo frame. The remote needs a new battery and cannot get the battery tray to release.
watch the remote tray carefully u will find direction arrow in this direction u have to push and pull outside the tray
Oct 17, 2014 | PANDIGITAL 7" Digital Photo Frame With...
I have lost my remote for my pandigital photo frame. Can I buy another?
...or you can call the company, they're pretty reliable about replacing remotes.
Jan 11, 2010 | PANDIGITAL 8.0" Digital Photo Frame...
SD Memory Card in frame-no pictures
1st: Make sure the SD card is in working order and not damaged.
2nd: Make sure you're using the right file type (.jpg, .png, .gif, etc) and size.
Jan 06, 2018 | PANDIGITAL (DPF802) Digital Picture Frame
Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
Dec 03, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Pandigital frame -how do I extend the stand?
Pull the stand out about an inch, and then SLIDE it downwards, opening it up to make it longer. Be gentle- it works!
Oct 19, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Pan digital 7 frame screen goes white
Removing the internal battery will clear all settings. I have done this on two different versions of the Pandigital frames (seems to be a very common issue) and it has corrected the issue instantly both times.
Good luck.
Sep 09, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
