Question about Cooktops
Grove sm3248e how do you operate this lift
HOW DO I CHANGE THE BURNER SWITCH ON MY RA524
Unplug unit. Remove knobs, if they interfere with lifting the stove top. Lift stove top from front of oven, proceed to inspect dials for damage. Repair or replace as needed.
Aug 22, 2014 | General Electric Cooktops
Access cooktop underside
Just lift it up. At the seems on each corner, pull up and it will lift.
Apr 15, 2014 | GE 30 in. JGP326 Gas Cooktop
How do I lift out built-in KitchenAid glass cooktop KECT 365 when mounting brackets wern't used
You are either:
A) missing the mounting screws and brackets that hold the unit in place
B) it is stuck and will require brute force to remove
C) both
Dec 30, 2013 | KitchenAid Cooktops
Viking pro 6 burner cooktop igniter won't stop clicking after lighting on two of the burners
Do not attempt if your stovetop is hot, you will get burned!!
This is an easy fix, the problem is your burners aren't lined up properly. Remove the iron grates (what your pots rest on) and the burner cap (the round black top on the burner) and finally the burner base (the round golden colored piece resting on the stainless stovetop). If you flip the base over you will see that it is keyed, meaning there is a grove that fits the indentation on the stove top. When you replace the base make sure to line the grove up with the indentation. If it's not flush with the stove top, slowly twist the round burner base until it falls into place. That's it!
Jul 09, 2009 | Viking Cooktops
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
Clicks occur in "low" position instead of "lite" position
Sounds like the switch electric sending unit needs to be Ither cleaned and dry good or replced. It's not hard at all, They are located under the knob switches, you will have to remove the knobs and the top cover, they look like a small square box wit a hole in the middle with two wires on the sides, just unplug the wires and lift the box off the switch rod. cleane them and dry them good and put them back.......that should do it.....Good Luck
Eddie Rentas
Tupper LAke NY
Jul 16, 2008 | Cooktops
Lifting the top to clean spills
Hi
Look under the counter top find the bolts that secures the stove top, unplug the power and remove the top, then look around the edges of the stove top and you should see some small screws that atach the glass to the frame, remove those and lift the glass carefuly, "DO YOUR THING" and then just reverse the steps and done.
Eddie Rentas
Tupper Lake NY
Jun 22, 2008 | Cooktops
Cooktop downdraft blower control knob broke off
Hello
Yes their is a way, you need to unplug the power, and look for the brackes that holds the cooktop to the counter, remove those scrwes and lift the cook top, then look under the top lip and you will see small scrwes, remove those and the glass will lift, then just reverse the steps.
Hope this help!!
Eddie Rentas
Tupper Lake NY
Jun 08, 2008 | Cooktops
Help
sounds like you got a short(probably one of your switches. do alll the knobe feel as if they're turn the same.usally when one shorts out itll operate differntly no resistance in the switch, can you lift stove top up and look under generally a visual inspecton will show where "pop" occurred
Feb 24, 2008 | Whirlpool RCS3014 Electric Cooktop
Jenn-Air JGD8130 Gas Cooktop
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Feb 21, 2008 | Jenn-Air JGD8130 Gas Cooktop
Cooktops Logo
75 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
