Question about General Electric Electrical Supplies
Tee 1 timer instructions
Looking to set timer for my lights 7 days a week
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
  • 4 Answers
SOURCE: how to set fm/1 stuz-l timer instructions
The timer works just like a lamp timer. First set it up on the correct time (white arrow on the inner circle). Next push the 15 minute increments down when you want the heater to run.
Posted on May 09, 2009
SOURCE: I have lost the instructions how to set a noma 7
Link show all Woods timers and manuals.
Noma is one name used to market Woods timers
Woods N1507 is also 49565
ttp://waterheatertimer.org/Woods-timers-and-manuals.html
Woods N1507 manual
http://waterheatertimer.org/pdf/N1507-programmable-outdoor-timer-manual.pdf
Add a comment if this manual does not match your timer.
Posted on Dec 13, 2010
SOURCE: I have a 7-day timer model em0101 and can't set it
There is a reset button to the left of the on/off button. It's recessed so you'll have to use a ball point pen or paper clip to reset the timer. The clock will flash 12:00 after it's reset. Press the clock button several times to select the day of the week. Then hold down on the clock button (third button on top right) and then twist the dial clockwise to set the hours, then counter-clockwise to set minutes. After the clock is set, press "timer" and do the same thing to set your on/off times. If you only use one timer, make sure the other 5 don't have anything in them.
Posted on Aug 02, 2012
dick97811
SOURCE: I have a HB88RC Intermatic 7 day / 7 event timer.
Just program it as noted previously and put the timer in Auto. Set the clock to 1 min BEFORE your earliest timer program is set to come on. When the clock hits the correct time, it will turn on. Then set the clock to the correct time and you're golden.
Posted on Dec 04, 2013
Where can I buy the Aube 7-Day Programmable 40-500w timer
You might be looking for T-1032 or T-1034 500watt timer
Identify model number on following link, and then google-search that specific model.
Link to instruction manual appears for each timer.
http://waterheatertimer.org/Aube-timers-and-manuals.html
Honeywell Aube in-wall timers can be used for single-pole or 3-way applications.
Look at instruction manual carefully for 3-way wiring.
Timer can be used for incandescent, halogen and CFL with minimum wattage requirement.
Since Aube timers have internal battery, they cannot be exposed to freezing temperatures or high temperatures.
Sep 28, 2011 | Aube Technologies Aube 7-Day Programmable...
The manual does not help. I'm obviously not understanding them correctly. I need step by step...all I want to do is have my lights come on from 7 pm to midnight every day of the week..they are not...
There is no repair for defective timer.
Sounds like the timer could have a conflicting program.
1) Good idea to test outlet with cheap circuit analyzer to make sure electric outlet is not causing problems for timer electronics.
2) Press reset button on timer face using toothpick to Re-set the timer
This will clear programming and then timer is ready to start over.
You can unplug timer from outlet while programming timer, so buttons and display are easy to see.
3) Open following link for clearly written instructions:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
4) I suggest setting timer program1 ON at 7:00pm, and choose all-days-of-week
And then set program1 OFF for 11:59pm all-days-of-week
Setting to 11:59 pm instead of 12:00 may solve problem.
5) Open following link for Kitchler manual:
http://waterheatertimer.org/pdf/Kitchler-15558WH-timer.pdf
6) If timer will not program correctly, and electric circuit is clean, then timer is defective.
This timer has 1 year limited warranty against workmanship defect.
I always suggest buying timers at local store because returns are cheaper, and if timer goes bad two years later, you can buy new timer and return defect in new package.
Kitchler is same timer as sold by Utilitec at Lowes, and Westek at Target.
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Kichler PLUG-IN ACCESSORIES - DIGITAL...
How to set specific dates to water with my T1030D? I don't need daily frequency for cool weather time. There is fequency dates to chooce on T1030, but not with T1030D.
1) Sept 2011.
If you have a T1030D timer instruction manual, then that would be helpful for many people.
Scan manual into .jpg format (file format) and then post images on Flickr.
Add a comment with link to those images so expert can access the information.
2) Currently the only instruction manual is the following, where you can also send information saying what your instruction manual says:
http://waterheatertimer.org/pdf/Instructions-for-setting-Gardena-T1030D.pdf
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
3) That being said:
Let me add some guessing, and then you can add a comment with what you observe.
Between us we might be able to work out a solution.
4) I don't think you can set specific dates on either T1030 or T1030D
It appears the T1030D is a weekly timer, just like T1030.
The word 'date' does not appear in T1030 manual except 'date of purchase.'
http://waterheatertimer.org/pdf/Gardena-1030-MANUAL.pdf
5) T1030D: each day of the 7-day week is broken into hour 1 through 24.
Each day can have between 1 to 3 settings. I think this is frequency.
You can set the watering run-time from 1 to 120 minutes for each set time.
Sep 01, 2011 | GARDENA Water Timer
I WOULD NEED SOMEONE TO TALK ME THROUGH IN PERSON , HOW TO PROGRAM THE TIMER FOR 8AM TURN OFF AND 8PM TURN LIGHT ON EVERY DAY OF THE YEAR - THE SAME TIME ...
If you want someone to talk to you, you will have to pay for phone help.
Here are the simplified instructions.
Press Mode to step thru various options, you only need to get to CLK.
Then set the hour, minute and day of the week first.
If you want the timer to go on & off at the same time for 7 days, you must program 7 times.
Good luck, Gary
Setting the Time of Day
Press MODE to go to the Clock (CLK) settings. The display will flash with 12:00 AM.
Press HOUR+ to stop the flashing.
Press HOUR+ and M+ to set the current time in hours and minutes.
Make sure that AM and PM settings are correct.
Note: The day of the week is shown at the bottom of the display. If you have not programmed the calendar settings,
be sure to also set the current day of the week while programming the current time. To do this, press DAY until the
correct day of the week is shown. The CLOCK settings are now complete.
Press MODE to go to the first PGM screen. See Fig.9
Use DAY, H+ and M+ buttons to set the days, hours and specific times that you would like the timer to turn ON.
(NOTE: Be sure the word ON is displayed when setting the ON time.)
Press NEXT ON/OFF to program an OFF time.
Repeat the same steps for all 7 ON/OFF operations, if required.
Aug 29, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
On this timer is the light color of time Day and the blue cover on time for night?
You posted under GE 7-day random vacation timer.
This timer shows 7 days of the week.
The nighttime hours are white with blue background.
Daytime hours are blue with white background.
Timer dial rotates clockwise, and make 1 revolution each week.
To set timer, manually rotate dial until current day and hour line up with 'time now' pointer.
Move slide switch to TIMER ON.
Timer randomly turns on-off at preset times.
To watch timer in action: turn lamp ON, plug lamp into timer, plug timer into outlet, and then manually rotate dial clockwise several rotations and watch lamp turn on-off.
http://waterheatertimer.org/images/GE%2050462%207-Day%20Random%20Vacation%20Timer.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#50462
Aug 13, 2011 | GE 50462 7Day Random Vacation Timer
Face of the timer doesn't indicate which numbers are a.m. and which are p.m., so how am I supposed to set the current time? There's an "8-4-12" that's not shaded and then an "8-4-12"...
You posted under Woods vacation timer:
See large image
This is a 7-day timer.
Days are printed on the dial.
Each day has night time with dark background and daytime in light background
If you want to set time for Monday at 12 noon, rotate dial clockwise until Monday 12 (in light background) line up with arrowhead located on inner dial.
After that, move switch to TIMER
Timer turns lights ON-and-OFF at random times throughout week
Jan 10, 2011 | Woods Indoor 7 Day Mechanical Vacation...
How many minutes does each pin represent?
You posted under Woods 59383 outdoor timer with 500 watt capacity.
This is a 7-day timer with segments (or pins) located around outer edge of dial.
Pull segments up to set OFF times.
Leave segments down for ON times.
Image of timer:
http://waterheatertimer.org/images/Woods-59383-image-500.jpg
Looking closely at image, there are 12 segments for each day.
So each on-off segment is 2 hours.
The dial shows days of week.
For example Monday (MON).
MON appears at 12 noon Monday.
TUE appears at 12 noon Tuesday
Rotate dial until current time lines up with arrowhead.
If this is not your timer, see all Woods timers and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Dec 13, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Utilitech model 0141224 wall switch timer. used on outdoor lighting to set up to 7 on/off cycles each day. im trying to turn on my porch light in the evening and off in the morning. there are NO...
As luck would have it I'm 60, and learned how to program your 0141224 wall switch timer.
You can see instructions with big print and pictures on following page.
Press CTRL key on keyboard and use scroll wheel on mouse to make web print bigger.
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Add a comment any time.
You have wired your timer correctly and the lights turn on when you push on-off button.
If lights do not turn on, we need to review the wiring.
Your timer looks like photo below.
I'm going to parrot back the manual with some extra words.
To start, press the reset button and clear any programming
Programing overview:
Each program has ON time ... and OFF time
So you set program1 ON and then set program1 OFF
When you set program1 ON, you choose the Day, hour and minute you want program1 to turn ON.
And then you set program1 OFF, and choose Day, hour and minute for program1 to turn OFF.
Your ON-OFF times for program1 should be on same days.
For example program1 ON for all-days-of-the-week, but program1 OFF is for TU Tuesday, then timer will not work.
IN this case, program1 OFF should also be set for all-days-of-the-week.
Let's start.
Setting the clock:
Press and hold CLOCK button
Keep holding CLOCK button and press DAY button until display shows current day (MO TU WE TH FR SA SU)
Press Hour button until current hour with am pm displays
Press MIN button until current minute displays.
Release clock button and current day and time show on display
At no other part of instructions do you press and hold one button while pressing other button.
Setting programs:
Press PROG button until "1" and 'ON' show on display
This is program1 ON
Press DAY button to choose which days for program1 ON.
You can choose: all-days-of-the-week and MO TU WE TH FR SA SU show on display
Choose individual days and MO or TU etc shows in display
Choose weekdays MO TU WED TH FR
Weekends SA SU show in display
Next step
Press HOUR button to select hour for program1 ON
Press MIN to select minute for program1 ON
Now program1 ON is ready, next, you will set program1 OFF
Press PROG button until "1" and 'OFF' shows on display
This is program1 OFF
Press DAY button to choose which days for program1 OFF.
( Remember, you want same days for ON and OFF)
Press HOUR button to select hour for program1 OFF
Press MIN to select minute for program1 OFF
Now program1 ON and OFF are ready, next, you will set program2 ON by repeating same steps above.
You can set up to 7 programs.
If you don't want to set program2, or any more programs, that's fine.
To exit programming and save your program, press CLOCK.
Now current time shows in display.
Final step: set MODE
Press MODE button until AUTO shows in display. You want AUTO for programming to operate lights. That's it, timer is ready.
If you're going on vacation, press MODE button until RDM shows in display, and then timer turns lights on-off at random
Copy and save these instructions to your computer so you have them next year.
Dec 04, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Electrical Supplies Logo
60 people viewed this question
Top General Electric Electrical Supplies Experts
hpgwva
Rob Bridges
Level 1 Expert
ken skalski
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
