Question about Adobe Acrobat 7.0 for PC
Adobe Reader Hi, My name is Bear and I have a real problem. Some how my Adobe Reader was deleted or renamed and I don't know how to undo it or what the new file name is. These are the responds I get when trying to undo or retrieve my adobe Reader: 1. Adobe Reader 7.0.7 msi file not found. Please verify the correct file name was given. 2. This file does not have a program associated with it for performing this action. Create an association in this folder. 3. This feature you are trying to use is on a CD-ROM or other removable disk that is not avaible. 4. Setup has detected that you already have a more functional product installed. Setup will now terminate. So this is where I stand and by not having access to the Adobe Reader I'm unable to install my External Hard Drive and I have about 25% of disk space left. I really do need the help and I need it bad and fast. Thank You Bear
  • Sherry Radcliffe Feb 06, 2009
    Thank You Beni S-P. It worked and how you told me to do it it was even better. A first time computer user could have followed your instruction without any problems. So once again Thanks to you my problem is solved.
  • 233 Answers
This is a nice little FREE utility you can try. Install Microsoft "Windows Installer CleanUp Utility"
If you find (PROGRAM NAME) listed just hit the delete button.
This will take care of the MSI problem.
Then do the normal Uninstall.
Uninstall Adobe Reader, do a search for all "Adobe" files and delete them. Go to the Adobe website and install the newest Adobe Reader 8.1 program.
CLEAN INSTALL needed here.
This time after the Uninstall, shut down completely for at least 30 seconds, and then restart.
Then do a search for 'all files and folders' - search for both 'Adobe' and then '7.0', with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those related files found.
You should do this search and delete whenever you Uninstall any programs. It will remove lots and lots of leftover junk files and corrupted files taking up room on your hard drive. It will also give you a "clean install" when you reinstall or install an updated program. (Do this ESPECIALLY when re-installing or updating to a NEW anti-virus programs and “Internet Security Suite” programs such as McAfee or Norton etc.)
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors, prior to installing or reinstalling.
Posted on Nov 05, 2007
Beni Tanks a lot is very very best information
Posted on Aug 08, 2008
  • 1,006 Answers
First download the registry cleaner here :
Then download also this one to clear all installed files : ( just open this program and if u dont see adobe installed there so go to the FIND/CLEAN TEMPONARY FILES )and go to the start -run-msconfig-startup and desable adobe from startup
Try to install in another directory ( not in program files just make new folder and install it there )
And if this solution was helpfull rate it as SOLVED PLEASE
While u installing
Posted on Nov 03, 2007
Need a adobe reader free dowload for Win Me to read PDF files
Posted on Feb 06, 2009
Some how my adobe reader has been deleted
Posted on Oct 16, 2008
  • 3 Answers
Easy solution. Reinstall or repair Adobe Reader, the reinstall will have the .msi installer in it.
Posted on Nov 16, 2007
I have an Acer aspire one netbook. ?; why cant i rename a file. Its in, Computer-Ascer(C:)-Users-. There are two files in this folder. Im not able to rename either. Is there a way to rename them?
If you have the file open or part of the content of the file is in use some place in the pc it wont let you rename it
try open the file as an administrator in safe mode or it might be read only attributes
copy paste soem place else see if it lets you then change name
rename and save some place else
There are several reasons why Windows might not allow you to delete a file:
  • The file might be in use in which case you can't delete the file until the program using it gives it up.
  • The file might be marked read-only.
  • The file name might be so long that Windows can't handle it. File names with more than 260 characters in them are often difficult to delete.
There are also several reasons why Windows might not allow you to change the name of a file; particularly its extension. All above apply here; as well as...
  • Your system may not be showing file extensions by default.
We'll cover that one first and the others in turn.
File Extensions Not ShowingThis is the most likely possibility for why you might not be able to change a file's type (i.e., rename the file extension). When Windows installs, one of the defaults is to turn off the showing of the full names for common file types. Basically, in Windows Explorer only the file's rootname shows; the extension is suppressed, yet is "shown" via the description in the File Type column of the Windows Explorer display.
When Windows is set up this way, if you attempt to change a file's name you are only allowed to change the rootname of the file but not its extension. So, if you have a file that shows up as MYFILE as file type Text and you attempt to rename the file to MYFILE.DOC what you really have done is rename MYFILE.TXT to MYFILE.DOC.TXT and the file type in Explorer will remain Text instead of changing to a Word File.
How to you fix this? FILExt has a different FAQ here that explains the procedure in detail.
The File is in UseA file in use by the operating system generally can't be changed while the file is in use. A file in use by a program may or may not be able to be changed. These are not hard and fast rules and exceptions abound; particularly in a multi-user environment. But, if you try to rename or delete a file and Windows complains that the file is in use don't be surprised.
To fix this you have to determine what is using the file. The error message that Windows pops up may or may not have that information in it.
If you don't want to experiment a bit to figure out what might be using the file you can restart the computer with all startup options turned off. This will most likely not run whatever was using the file and the system will allow you to rename the file. Recognize that if you do this and then restart the computer with all startup options enabled some program will likely complain that it can no longer find the file you just renamed. This may or may not affect how your system performs (or even operates at all).
To change the startup options, use the System Configuration Utility.
  • Click on the Start Menu.
  • Click on the Run item.
  • Type msconfig into the dialog box and click OK.
Use the various startup options settings to reconfigure your system startup as needed to find the subject program or process. Remember the caveat about how changing the name of a file a program or the system uses might affect system behavior. Keep good records so you can reverse what you did if necessary.
If you want to experiment a bit, press the Control-Alt-Delete keychord (press all three keys at the same time) only once (if you press the keychord twice you will restart your computer). The Windows Task Manager will appear. Take the Applications tab and see if anything is running. If so, stop those programs (it's usually better to switch to the program and then close it from the program instead of picking Close from the Task Manager). Wait a bit as it sometimes takes Windows a bit of time to release all program assets. Then try to rename or delete the file. If you now can rename or delete the file you know one of the programs was using it (stop only one program at a time if you really, really want to know which one).
If you still can't rename or the file you need to go to the Processes tab. There should be a number of running processes. Two of these are particularly important: Explorer and Systray. Do not end these. The other processes should be able to be stopped. Try stopping those processes you may recognize one at a time. Attempt to rename or delete the file after each has stopped. If you can, then you know what process was using the file. Keep going until only Explorer and Systray are running. If the file is still in use you've got your answer. The most basic processes in the computer are using the file. The same caveat as above applies: the file was in use for a reason and if you rename it or delete it the system may become unstable if you rename the file.
File is Marked Read-onlyThis is the easy one. To find out if a file is marked read-only right click on the file in Windows Explorer. Select "Properties" from the menu that pops up. At the bottom of the dialog that appears are the attributes for that particular file. See if the Read-only box is checked. If so, you won't be allowed to modify the file. To take the read-only attribute off the file uncheck the box. Again, be aware that if some program requires that file to be read-only and you change that attribute or the file's name you may have system problems. Use caution.
Note: If the file is in use (see above) or you don't have the necessary permissions (i.e., you're not logged in with administrator status) the read-only box may be greyed out and until you correct whichever condition is to blame you will not be able to change the attribute.
How does a file get to be read-only? Most of the time it's by copying the file from a CD. Most CD media, by design, is read-only and often when you copy a file from a CD (or an install program copies the file) a read-only attribute will be given to the file because it was read-only on the CD. This doesn't happen often, but does happen often enough to cause some people problems.
File Name is Too LongWindows has special problems dealing with extra long path/filenames. If the combination of the path and file names gets close to 255 characters (127 for Windows 95/98/ME) Windows will likely not handle it well if you try to delete or rename it (you can create it but not change it). While there are programs that can handle names that long or longer (e.g., FileBoss) the first thing to try would be to rename some of the folders that lead up to the file itself. Back the directory display up one level and then select and rename the folder the file is in. Try a single letter (obviously, keep a record of what folder you named to what so you can reverse the process!). Then, go back to the file and see if Windows then allows you to rename or delete it. If not, go back yet another folder and rename that one and so forth. At some point you should be able to find a series of reduced-length folder names that allow you to then rename the offending file to a short enough name to allow you to then recreate the original directory tree and still work with the file in question.
Special Programs for Deleting Files/FoldersSometimes you can't seem to delete a file or folder no matter what you do. In this case there are a few programs that might help you.
If, after all this you still can't rename/delete a file, not certain what else to suggest. Others have this problem often and as different ideas might come up in the FILExt forum I'll change this FAQ to include them. If you find a method that works for you and is not in this FAQ, please drop FILExt a note with details on that method so it can be added to the FAQ.
Jul 24, 2012 | Acer Computers & Internet
Cannot open a PDF
Hi! In order to view PDF files, you will need a software like Adobe Reader. If you already have one but you still can't open PDF files I suggest you just reinstall it. If you don't have one yet then you can download it online for free here:
Thanks for using Fixya!
Don't forget to rate =)
Jun 02, 2011 | Adobe Computers & Internet
I dont have adobe reader. it was deleted by my friend who install my internet before.
Hi welfredo,
Go to and you can download Adobe Reader X from there.
Hope this helps!
Don't forget to rate;)
May 20, 2011 | Computers & Internet
What must I do if when I open adobe reader it say me: invalid plugin detected. Adobe reader will quit. ????
tried up-issues (Adobe Reader 8.1.2+) and got the same error "invalid plugin detected. Adobe Reader will quit".
I fixed this error by following laborious steps described in the Adobe Technical Support Home.
Not sure if this helps you guys; but worth a try. Developers should say if this the real cause.
You can find these in the "plug-ins" folder. [C:\Program Files\Adobe\Reader 9.0\Reader\plug_ins]
"HAEvents32.api" is the main culprit. Along that, I removed "Helmant32.api" and "Helmbkmk32.api".
Without deleting these two, an error or two might come but still PDF will work. I tried all these combinations.
Note: Delete these files if present anywhere else in the system else they recreate themselves.
Thanks every one.
Dec 11, 2010 | Adobe Computers & Internet
.MOD files in Adobe Premiere Pro C3
WOAH thanks changing the file names worked! That took me forever to figure out!
Oct 05, 2008 | JVC Everio GZ-MG30 Camcorder
File copy error.
maybe your drive is already full, if your drive is already full try to delete the temp file or delete your unnecessary files, if not try to check the file that you are trying to copy, maybe there some associate file which have a long file name, try to rename it but copy first the original file name to notepad, and after copying rename again your file that you renamed before, if still not tell us what kind of file you want to copy.
Sep 08, 2008 | Computers & Internet
I've tried downloaded updated versions of adobe reader; have done so, but there are older versions which now interfere. I'm unable to open any version at this time. Can you help?
The only recommendation i could make for you is just uninstall the previous versions then re-install the one version you would like to use...That's the only solution I know so far...
Jul 23, 2008 | Adobe Acrobat 7.0 for PC
Patch 6.0.1 downloads , then says corrupt something about windows not letting through
Uninstall Adobe Reader, do a search for all "Adobe" files and delete them. Go to the Adobe website and install the new Adobe Reader 8.1 program.
Oct 14, 2007 | Adobe Acrobat 6.0 for PC
Can not read Acrobat Reader document
Sep 26, 2007 | Adobe Acrobat 6.0 for PC
Adobe Acrobat 7.0 for PC Logo
5,793 people viewed this question
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
