Question about Whirlpool Duet GHW9150P Front Load Washer
Cost repair bad bearing on washer whirlpool washer
2 Suggested Answers
  • 41 Answers
SOURCE: Whirlpool AWM 5145 washer the drum bearing has
It's not a DIY fix mate you'll need a new rear tub half which are around £110
Posted on Jun 12, 2010
Whirlpool Cabrio washer model WTW7800XL2 sound like jet engine during spin cycles
Tub bearing is bad. Repair on that would probably cost over half of what a new machine would cost unless you do it yourself.
Oct 23, 2017 | Whirlpool Washing Machines
Loud noise while spinning, sounds like a bad berring
You are absolutely right. Your washer has bad tub bearings, the Cabrio washers are notorious for this problem. The bad news is that the bearings cost over $300 just for the part alone, not including paying a technician to come out and replace them. If you can tolerate the noise then you can continue to use the washer but it will eventually completely go bad, but this will give you time to find a different washer. The top three problems with the Cabrio washer is the tub bearings ($300+), the main control board ($200), and the drain pump cracking and leaking all over the floor ($100).
Hopefully I have helped you out, sorry it wasn't good news.
Dec 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
Whirlpool washer making loud noise when spinning
It sounds like you need a bearing job. The bearings in the back half of the wash tub go bad. and the washer gets loud .It's an expensive repair. I hope this helps
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Cabrio sounds like a jet engine while in the spin cycle
believe the bearings can be bought locally,but water seal has a Whirlpool number on it that will not come up on pricelist on my Whirlpool program.I am looking for a way to cross ref. this seal and repair the tub.The last tub was over 197.00 cost for new tub and drive shaft ,bearings and seal.The bearings are Korean made and can be bought locally for alot less than a whole new tub.This is an ongoing problem with the Cabrios and Maytag Bravos that I have seen lately.Also a few of the Sears Kemores out there.There has to be an easier and cheaper repair for these thousand dollar machines.I dont like telling the customer its going to cost them 400.00 to repair their washer when it is not even a year out of warrentee.If anyone has the seal number or a cross number please post
Nov 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool ghw9100lw2 bearing repair
It is not a hard job to replace the tub. Just time consuming. I replaced the back portion of the tub where the bearing is. If the inner tub shaft has any wear on it , replace that as well. Otherwise youll have the same problem in a month. Its an easy fix if your patient. I paid about $130.00 for the rear portion of the tub. I'm not sure about the inner tub.
Mar 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio Washer
it is the bearing, call 1800-905-9505 and ask for a service smart agreement cost about 200 and it will cover your washer for 1 year parts and labor and the machine will get fixed
Feb 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Rear bearing noise when drum rotates
If the rear bearing is bad it will require the replacement of the entire rear tub shell. This is because the bearing is molded into the plastic and cannot be replaced separately (I know, its a stupid design). Sometimes additional damage can occur and the inner spin basket and front shell may also need replaced. In addition, what may seem like a bad rear bearing, might be a broken tub support on the spin basket. In a nutshell, you may have to replace both tub shells and spin basket at a minimum. With parts and labor the repairs could cost $600-$800. If you have no extended warranty or service plan coverage, it may not be worth the effort to repair due to the excessive cost. Sorry...I wish I had better news for you. I hopes this provides you with some answers.
Oct 05, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
18 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
