Question about Canon Compatible Toner Cartridge Replace E40,E31,E20,E16 Printer
My paper tray is broken for cannon e20 - Canon Compatible Toner Cartridge Replace E40,E31,E20,E16 Printer
3 Suggested Answers
  • 42 Answers
SOURCE: we have a Cannon Pixar ip4300 I accidently kicked the paper tray door once when it was open and now everytime we try to use the printer we get an error message about that we need open the paper tray d
I think your on the right track, youv'e probably dislodged or broken a micro switch, screws are mostly underneath, be careful this could turn into a Mecano Nightmare! Good Luck the Yeti
Posted on May 20, 2009
SOURCE: the cannon image runner shows remove paper from out side tray but there is no paper in out side tray also it can't take any photo copier why?
delivery sensor problem
Posted on Aug 29, 2012
Cannon IR 1600 Rec paper jam message.no any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
My paper seems to not want to feed properly it suddenly shifts to the side....Cannon ip3500
Make sure that the paper guide is up against the right hand side of the paper in the feed tray. You should not be adle to move the paper sideys in the feed tray. If you can, the guide is not set right.
Feb 11, 2011 | Office Equipment & Supplies
Hi, I have an e20 cannon copier. There was a paper jam, the paper was removed and then when I go to restart the copier it still has that paper jam icon showing. I looked everywhere in the machine and there...
Hi, I solved the problem. I had another employee look it over and there was still a teeny teeny piece of paper that was still jamming it up. So once that was removed the copier started working okay again. Thank you for taking the time to try and help me. Sould I encounter any other copier problems I'll get back to you.
Oct 12, 2009 | Canon Compatible Toner Cartridge Replace...
We have a Cannon Pixar ip4300 I accidently kicked the paper tray door once when it was open and now everytime we try to use the printer we get an error message about that we need open the paper tray d
May 20, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Cannon mp780 paper pulls to right hand side and jams everry time
printer loading tray have problem /something struck at left side of tray /check if something/if none / sometime it connot be seen its hide five cents .
clean also the incoming roller and outgoing rooler w/cotton tips w/ rubbing alcohol. test the printer.
Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
My cannon printer jams
This printer cannot use cheap paper. Make sure you use 20lb #92 paper. I had the same problem till I changed paper. Hope this helps
Dec 07, 2006 | Canon imageCLASS D661 Digital Printer
11 people viewed this question
old marine
old marine
