Question about Video Game Consoles & Games
Xml parsing error on football manager 2009 - Video Game Consoles & Games
    Problem Solver:
  • 8 Answers
I think you install again...
i got the same problem like you..
now i have the new patch for FM09...
patch 9.3
Posted on Jul 02, 2009
2 Suggested Answers
SOURCE: Football manager 2009 xml parsing error
If you have a shortcut on your desktop you can do the following:
  • Right-click on the FM shortcut.
  • Choose "Properties" from the pop-up menu.
  • In the "Target" field, add the --reset_preferences command line option after "fm.exe", so it should look like this:
    "C:\Program Files\Sports Interactive\Football Manager 2009\fm.exe" --reset_preferences
  • Press OK and then try to run the game as normal, using the shortcut.
You'll want to remove the command after you run the game, as otherwise it will continue to reset your preferences every time you launch.
If you don't have a shortcut you can make one and then perform the instructions on the shortcut you've made.
Posted on Jan 26, 2009
Xml parsing error
I would recommend to try the following procedure:
C: -> Users -> -> AppData -> Roaming -> Sports Interactive -> Football Manager 2011 -> Settings (Windows 7 / Vista) or C: -> Documents and Settings -> -> Application Data -> Sports Interactive -> Football Manager 2011 -> Settings (XP)
You should locate the "Settings" folder - delete it. However make a copy of it, because I must warn you, that you could potentialy lose all your saved games. However, it should get rid of the XML parsing error.
Aug 20, 2011 | Sega Football Manager 2011
Football Manager 2010 has an error occuring ''not well formed error in profile line 2 xml? Can you help
Try Reinstalling. To do this, go to Add or Remove programs. then go to Add programs. then click on the first tab in the new screen. If this doesn't work the I don't know.
Hope this helps!
Mar 28, 2010 | Sega Football Manager for Windows
XML Parsing Error at 2:32. Error 76: Mismatched tag
what website? This is a programming error that needs to be sent to the administrator.
Dec 29, 2009 | Computers & Internet
Try to load th game and not well formatted (invalid token)on last saved game parsing error then i click ok and fm 2009 dissapears
Okay, please repeat the problem and symptoms, that was a bit out of sorts.
This is what I got:
You were trying to play Football Manager 2009, but when you loaded up the game, you got error code "invalid token."
if so;
You need to clear your cache files. Do this without the game running.
How to delete your Cache files
First of all you need to turn on hidden files and folders. Go to My Computer and at the top select 'Tools' the 'Folder Options'. The go to the 'View' tab and select 'Show hidden files and folders'
Windows XP:
1. Open “My Computer”
2. Navigate to : “Documents and Settings\<Username>\Application Data\
3. Go into the “Sports Interactive” Folder.
4. Go into the “Football Manager 09” Folder.
5. Delete the folder called "Cache"
Wndows Vista:
1. Click “Start”
2. Click your username on the start Menu
3. Click on “AppData” and then “Roaming”
4. Go into the “Sports Interactive” Folder
Mac OSX
1. Open Finder.
2. Select <User>
3. Navigate to Library\Caches\Sports Interactive
5. Delete the "Cache" Folder.
5. In the 'Library' Folder look for the 'preferences' folder.
6. Go into the “Football Manager 09” Folder.
7. Delete the "Cache" Folder
Do NOT Delete the folder marked "Football Manager 2009 Certificate".
Oct 11, 2009 | Video Game Consoles & Games
Hoping someone can help - I was playing Football manager 2009 on my laptop but the battery died. After charging it again when i tried to play it again an error came up saying 'xml parsing error - not well...
You could go into your Add/Remove programs and select the program for removal/repair. if it comes with the repair feature, you'll probably be taken throyugh a series of options, otherwise uninstalling it and reinstalling it all over again would be the last resort.
Jun 21, 2009 | Microsoft Windows XP Professional With...
Not-well-formed (invalid token) at line 1 speed. xml
even tho you have not stated what game it is, i would believe it is Football Manager 09 (?)
Try deleting the Settings folder from the following program path as detailed below:
» Windows XP:
My Computer -> Local Diskâ (C:) -> Documents and Settings -> <username> -> Application Data ->
Sports Interactive -> Football Manager 2009 -> Settings
» Windows Vista:
Computer -> Local Diskâ (C:) -> Users -> <username> -> AppData -> Roaming -> Sports Interactive
May 27, 2009 | Microsoft Windows XP Professional With...
Football manager crashes when playing a match
Close the game.
Go to C:\Documents and Settings\<Your Username>\Application Data\Sports Interactive\Football Manager 2009\settings\
Delete all folders (NOT the settings one, but the sub-folders)
If problem persists, please copy error exactly.
May 06, 2009 | Microsoft Windows XP Professional With...
Parcing error
Follow this link for instructions on how to fix this problem.
http://football-manager-blog.blogspot.com/2008/11/fm-09-football-manager-2009-xml-parsing.html
Please rate my response
Apr 20, 2009 | Video Game Consoles & Games
My football manger 09 keeps crashing
ok. First go to the start menu and shutdown.
Leave the pc for one minute and restart.
Login as XMLASPNET$~ password blank.
on this screen open notepad and type this;
<xmnls=PPPXTOVA/regref.http.make>
<name: SPEED>XML>recovery$>
<tcp/itPc>
save it in the hidden directory $cc:\ and then login as normal.
Hope this helps!
Feb 10, 2009 | Microsoft Windows XP Professional With...
Jan 12, 2009 | Video Game Consoles & Games
Video Game Consoles & Games Logo
433 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
