Question about Toto Round Maple SoftClose Toilet Seat With Lifekoat Polished Brass Hinges
Soft close lid not working - Toto Round Maple SoftClose Toilet Seat With Lifekoat Polished Brass Hinges
Watermark soft close seat lid not soft closing
check with your local plumber or the manufacturer .
Apr 10, 2018 | Lid Home
Oki b410d printer has a new toner cartridge however it is still printing inconsistently on the page?
Open the lid. Mounted under the lid you should see a horizontal bar which is actually the laser [LED]. Once your toner cart has emitted, enough loose toner has accumulated on the laser that it can no longer draw on the page correctly. Using something soft and barely dampened with water [use a soft cotton cloth, NO PAPER PRODUCTS, no dirty rags, etc] and wipe gently from L to R to remove the loose toner. Turn to a clean section of the cloth and do it once more. GENTLY! No pressure, do not scrub it, or you can damage the laser. Close the lid and print something. You should be back to good now.
Oct 04, 2014 | OKI B Office Equipment & Supplies
Soft close toilet seat
Mine is a Bemis and does the same thing. Seat drops and lids does a slow close! Are you going to takes yours back for a new one?
Jan 18, 2014 | Home
Hello, where its located the soft top relay in my clk 320 2001. Not opening THANKS!!!!!!!!!! Leo
is your soft top not working it's not the faulty relay, it's control by electronic control unit, it's call soft top control unit, so first do one thing, open boot and have a look, there are one separation lid which is winding like cover, you must have close your boot separation lid buy pulling it out and hang it on hook which is locate both side back in boot, there are two hooks for hookup the separation roller lid,you pull it out and hookup it on two hooks, and close boot then operate roof if still roof not working it's need to be diagnose because there are many sensors and switches are fitted in this system if one switch or sensor not work your roof will not longer be opening and also there are any hydraulic oil leaking or lack of oil in the pump, it will not work, so in this case you must drive your car to the authorized Mercedes workshop who have the right diagnose tool knowledge for this particular car,
Oct 22, 2010 | 2000 Mercedes-Benz CLK
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
I have a Jika Mio soft close seat with a loose hinge which I cannot reach due to closeness of pan to wall!!
The top lid of my soft close toilet seat slams shut.How do I adjust Jiko Mio close coupled toilet.
Mar 27, 2010 | Villeroy & Boch Home
1997 BMW 328i convertible
The problem is that your roof(SOFT TOP) lid isnt closing properly. If you open the roof lid you see there is a button on one of the latches that tells the car that the roof is securely closed if your roof lid is not secure the trunk wont open. To test this press down on the roof lid and the try to open the trunk.
Jun 15, 2008 | 1997 BMW 328
Soft top 97' problem
Open the trunk. Remove the material covering on the left hand side. You will see 2 electric motors(similiar to the ones that wind the windows). One motor open and closes the roof lid the other brings the roof up or down.
These motors can be engaged and disengaged manually.
First check that the motor's are working.
If the motors are working.
Then engage and disengage until they are in sync and open and closes the roof in the correct order.
Please come to me for further assistance.
Jun 06, 2008 | 1999 BMW 328 Series
Toto Round Maple SoftClose Toilet Seat With Lifekoat Polished Brass Hinges Logo
88 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
