Question about Kitchen Appliances - Others
Tefal Express Boil BR40
Only half the water is coming out. The dial is set to full. The jug is full and sitting on straight
SOURCE: Tefal Pro Express - Constant Steam
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
Posted on Feb 04, 2009
ginko
  • 19396 Answers
SOURCE: Tefal Express 1750 has water dripping from it when using steam
That means that water is not heated properly and does not produce steam.
Try a complete descaling, often this happens because the water reservoir and heating element is covered with scale.
Posted on Feb 17, 2009
SOURCE: tefal pro express turbo water flowing out of iron
i have a tefal pro express gv8110 iron and it keeps leaking out water onto the clothes and doesnt seem to heat up. i have only had it for 22 months so im not sure why it has been doing this. it also doesnt seem to let the steam out like it used too. please could u help me
Posted on Sep 15, 2009
  • 572 Answers
SOURCE: Washing machine Water level will not fill beyond half full
if this is a commercial. thats as much water it gets. most of them are energy star
Posted on Feb 07, 2010
heatman101
  • 43501 Answers
SOURCE: my tefal express turo iron the fill icon is
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
With the water jug full of water, the machine still keeps saying refill water.
unplug from outlet for 20 minutes. If the jug is removable, thoroughly clean the area where the jug sits and the part of jug that sits on the coffee maker. If that doesn't work, look online for the makers web site / phone number and ask for help.
May 16, 2016 | Coffee Makers & Espresso Machines
Antifreeze capacity
Usually what I do is I'll get two gallons of straight antifreeze. I'll take one and pour half into another empty jug then I fill both with water. Pour one in then the other one until it gets full. Then crank vehicle then fill it again
Mar 04, 2015 | Cars & Trucks
I have a 98 pontiac transport I have new lower intake. Gaskets,water pump,t-stat new radiator but I still only have air Coming from the bleed screw and it over heats.there's no water in my oil,what...
just keep bleeding the air out. unless you have a blown head gasket or cracked head, there is no way for the air to get in there accept for the work you have done. you can get a fitting that will screw in to the bleed port and hook a hose on it, stick the end of the hose in a jug half full of coolant and start the car let it idle you will see the bubbles coming out let it run with out the radiator cap on when it starts filling the jug with coolantwhen you dont see any bubbles put the cap on and kill the car. Replace the bleed plug and fill the radiator back full , make sure the over flow tank is full of coolant start the car let it run it will get rid of any other air and push it in the overflow tank and when it cools off it will suck the coolant back to the radiator.
Jan 24, 2013 | Cars & Trucks
How many gallons do I need to fill 1990 ford super duty
1 jug straight antifreeze 1 jug 50/50 antifreeze and the rest with water.be sure to save a little of straght for overflow jug if it has one. maybe 1/4 jug. this applys to a empty system
Nov 15, 2012 | Cars & Trucks
How to descale tefal express boil
I was searching for this solution then I found the manual in a draw so to help anyone else with the same problem the method is:
Descaling should be carried out every 3 months.
Fill the appliance to max. Dispense maximum size cup to a large cup.
Add descaler to the cup then pour back into appliance.
Dispense the mixture in the appliance into the cup and disgard.
Continue until applance is at minimum water level.
Empty the appliance then refill with water and run it through the machine and disgard until its at minimum then empty the appliance again.
It should be ready for use. You can use 1ltr white (and only white) vinegar instead of the descaler and water mixture.
Jan 24, 2012 | General Kitchen Appliances - Others
My sunfire overheats and leaks out overflow everytime i drivee it.i changed water pump,thermostat the fan is working fine and had a water pressure test done last mth
DID YOU BLEED AIR OUT THE COOLANT SYSTEM.TO BLEED COOLANT SYSTEM, FILL THE COOLANT SYSTEM THROUGH THE RESERVOIR TANK OR THE RADIATOR UNTIL THE FULL COLD MARK IS REACHED.BESURE TO USE 50/50 HALF WATER AND ANTIFREEZE.YOU CAN BUY ANTIFREEZE THAT IS ALREADY PREMIX 50/50.AFTER ADDING ANTIFREEZE TO RESERVOIR OR RADIATOR FILL RADIATOR TO FULL MARK OR IF YOU DONT HAVE RADIATOR CAP ON RADIATOR POUR ANTIFREEZE IN THE OVERFLOW JUG UNTIL COOLANT LEVEL STAY THE FULL COLD MARK.WAIT AWHILE UNTIL COOLANT LEVEL STOP DROPPING.NOW INSTALL THE RADIATOR OR OVER FLOW JUG CAP.START THE ENGINE AND ALLOW IT TO RUN UNTIL NORMAL OPERATING TEMPERATURE IS REACHED AND THE UPPER RADIATOR HOSE BECOME HOT.STOP THE ENGINE AND OBSERVE THE COOLANT LEVEL IN THE OVERFLOW JUG. THE COOLANT LEVEL SHOULD BE AT THE FULL HOT LINE.ALLOW THE ENGINE TO COOL UNTIL THE AMBIENT TEMPERATURE IS REACHED THEN CHECK THE COOLANT LEVEL IT SHOULD BE AT OR ABOVE THE FULL COLD LINE.ADD MORE COOLANT IF NECESSARY. WARNING BECAREFUL WHEN OPEN THE RADIATOR CAP OR JUG OVER FLOW CAP.USE A LARGE RAG OVER THE RADIATOR CAP TO KEEP FROM GETTING SCALDED.OPEN RADIATOR CAP A LITTLE AT A TIME TO KEEP FROM GETTING SCALDED.WAIT UNTIL ENGINE COOL DOWN BEFORE OPENING RADIATOR CAP OR OVERFLOW JUG CAP.WEAR SAFETY GLASSES.
Jul 12, 2011 | Pontiac Sunfire Cars & Trucks
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
POWERFULL TEFAL PRO EXPRESS 2911 STEAM GENERATOR IRON how do i clean the plate
strait vinager fill it to full let sit over night then empty
Feb 16, 2011 | Vacuums
Canon i560 has full ink and when it comes out there is no print at all
your printer cartriage is blocked. try this. boil half cup of water then insert the cartriage head in boil water for 30 sec and then try
Jan 01, 2011 | Canon BubbleJet i560 InkJet Printer
I have been given a Kenwood BL300 blender. After using it to make breadcrumbs, I undid it somehow and now I can't get it back together. Can't remember if the blade goes straight into the base or the jug,...
You need to unfasten the white base from the clear jug, then the rotating blade will sit inside the white base, with the blade facing upwards. The white rubber flange goes in next. Then screw the assembled base back into the clear jug. The jug should then fit on to the stand.
Dec 08, 2010 | Kenwood BL300 SingleSpeed Blender
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
