Zanussi jet system 1200 fjdr 1266w comes on and does not start working
  • 1294 Answers
SOURCE: zanussi jet system 1200
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Press "end of cycle" to finish the mid stoppage..
Rate me pl.....if helped.
Posted on Jan 02, 2008
Timon90
  • 126 Answers
SOURCE: Zanussi jetsystem 1200 XC leaking from underneath
Check the door below, it's pretty vulnerable.
Posted on Jan 25, 2008
dauphine
  • 207 Answers
SOURCE: just wont work
  1. Turn it off.
  2. Unplug it.
  3. Wait 5 or 10 minutes.
  4. Plug it in.
  5. Turn it on.
Posted on Apr 09, 2008
SOURCE: ZANUSSI WASHING MACHINE
I found that it displays this message when the outlet to the sink is blocked. It is normally blocked with fibres at the drainage end. hope this helps
Posted on Sep 01, 2008
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Posted on Feb 08, 2009
Jets system has weak flow can I clear it?
most hoses come with built in filters can b removed
Feb 20, 2015 | Zanussi Washing Machines
Can anyone help ive got a zanussi FJDR 1466 W. e91
I had the E90 problem about a year or so ago. Havng had a problem with my Zanussi dishwasher a common fault with zanussi white goods is that they don't solder major joints on the control boards very well. (Probably tryng to economise of the amount of solder they use)
Check all the connections on the control board are tight and haven't burnt off the solder. This worked for me and we haven't had this code since.
Nov 02, 2009 | Zanussi ZWF1430W Front Load Washer
WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
Apr 04, 2009 | Zanussi FJD1266W Front Load Washer
Dec 19, 2008 | Zanussi FJD1666W Front Load Washer
Jan 19, 2008 | Washing Machines
Jan 02, 2008 | Zanussi FJS1225W Front Load Washer
seems to be a problem with the filter. was with mine.. one thing i always forget to clean it regularly.
Be careful when open the little hatch thingie , there will be water coming out . so prepare with a bakingtray and kitchen towels. and open it SLOWLY!!! so the water doesnt totally soak the floor.
then clean clogged up filter. at least that solved the problem in my case, hope it works
Sep 29, 2007 | Washing Machines
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
