Question about Kodak EasyShare V705 Digital Camera
How to repair a kodak v705 Memory card reader
  • 373 Answers
SOURCE: kodak v705 #E45 error
Not promise anything
try kodak.com/code
Posted on Feb 04, 2009
Rammsteins
  • 300 Answers
SOURCE: kodak digital camera V705 -error 45
Hi!
E45 means that a focus error occurred or the MCU BOARD malfunctioned. I'm afraid you will have to give it away for a repair. It's a hardware problem. You should contact your local Kodak service center.
Tom
Posted on Aug 01, 2009
jonniewalker
  • 1031 Answers
SOURCE: Kodak EasyShare C633 not reading any SD Card
check the manual for any such thing like "memory card problem" or open the page that talks about it, it may contain useful info
usually there is a preferred type recommended to use
using a memory card that was installed in other cameras may change its format or file structure, this may cause your camera not to recognize it, try formatting the card and then install it again, most cameras have a "format" option in the menu, try it out
there might be a "reset to factory defaults" option, this may reset your camera to the way it was originally it was in, could solve it
Posted on Nov 02, 2009
leepania
  • 1099 Answers
SOURCE: I put a new memory card in our Kodak EasyShare
Your camera is only supporting SD/MMC Cards (up to 1 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.
1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Posted on Jan 07, 2010
n00h
  • 624 Answers
SOURCE: My Kodak EasyShare V705 keeps telling me that the
Hello and Welcome to Fixya!
Turn off the Device, put the Card out and see there will be a small switch/latch on some site of the card, and there will be stated the Lock/unlock state, if it is locked. change the position according to the description.
I'm attaching a photo for your convince.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
Posted on Jul 19, 2010
V705 camera says the sd card is read only
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 14, 2014 | Kodak EasyShare V705 Digital Camera
How do i save todays pictures on my kodak z18
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 29, 2012 | Kodak Cameras
Kodak easyshare v705 does not work with my Mac 10.7.4
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Jul 28, 2012 | Kodak EasyShare V705 Digital Camera
Kodak easyshare v705 erreur e45
Hi
Error 45 on a Kodak EasyShare V705 indicates a hardware failure. Unfortuantely you will have to contact your local Kodak repair centre to get a quote to have it repaired.
Sorry to be the bearer of bad news.
Regards
David
Feb 13, 2011 | Kodak EasyShare V705 Digital Camera
My Kodak V705 has Error #45 lcd cant come so that i can take pictures?says see user's guide what should i do?
Hello and Welcome to FixYa!
The Actual reason stated my Kodak behind this error is the e45 error denotes that it's time to repair your camera. It's also indicative of a lens retraction. It could be that your battery is long in the tooth and doesn't have enough capacity anymore to adequately power the camera. Lithium Ion batteries do lose capacity over time and going on 3 years, a simple replacement of the battery could solve the issue.
Also try to turn off the Cam, remove the memory card/any accessory attached to the Cam, remove the battery, clean the contacts, then reinsert the battery and turn on the Cam. Absent that, a repair is required.
Concerned, Nooh
Aug 08, 2010 | Kodak EasyShare V705 Digital Camera
I have error code e45 displayed on the screen, my camera model is Kodak V705.
Link
For basic trouble shooting, you can try the following:
> Turn off the camera,then on again
> Remove the memory card
> Turn off the camera, remove the battery, wipe the contacts with a clean dry cloth.
> Insert a new or charged battery
> If the problem get exist, try asking for help from the nearest Kodak Store.
You may also want to browse your camera manual to learn more of your camera for best result.
God Bless
Aug 03, 2010 | Kodak EasyShare V705 Digital Camera
My Kodak EasyShare V705 keeps telling me that the memory card is protected and to reset switch on memory card. How do I do this?
To remove the write protect lock, take the memory card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab up to unlock it, it will be at the side of the card like this 59a6de4.jpg .
Regards.
Jul 19, 2010 | Kodak EasyShare V705 Digital Camera
I have a v705 camera and it shows error45 pls suggest
This is a lens error. KODAK suggests a repair for this fault.
However due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 30, 2009 | Kodak EasyShare V705 Digital Camera
Kodak digital camera V705 -error 45
Hi!
Tom
Aug 01, 2009 | Kodak EasyShare V705 Digital Camera
Kodak v705 #E45 error
try kodak.com/code
Feb 04, 2009 | Kodak EasyShare V705 Digital Camera
Kodak EasyShare V705 Digital Camera Logo
13 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
