Question about Xante Office Equipment & Supplies
Xante adjust trapping - Xante Office Equipment & Supplies
Xante cl30 printer drivers for windows7 32bit & 64bit
go to www.xante.com -->support -->drivers & docs -->legacy products -->cl30
Aug 20, 2012 | Xante CL30 HSE Laser Printer
Fatal error 133 xante cl 21. Course for this
yellow led head. swap yellow with cyan and see if the error changes
Feb 14, 2011 | Xante CL30 HSE Laser Printer
My Xante Accel-a-Writer is not communicating with my macmini. I understand that OSX 10.6 doesn't support appletalk, and have configured the xante as an LPD printer and entered its IP address. The mac...
First, I would recommend that you connect the Xante Accel-a-Writer to a Windows OS computer (xp/vista). Observe if it will function perfectly. This will determine whether you are doing something wrong or if the problem is from the Xante Accel-a-Writer or if they don't support each other.
You can test the Xante Accel-a-Writer on a friends windows OS computer if you don't have one.
Let me know the out come so that I can direct you further.
Good luck.
Oct 19, 2010 | Office Equipment & Supplies
Good day I have a Xante Ilumina 502, when i print on 300gsm and up there is a magenta background. How do i solve this
Your settings are incorrect, adjust media type and media weight. This settings adjust the temperature of the fuser. If fuser to cold you will have ghosting and fuser to hot image will stick to fuser.
Mar 31, 2010 | Xante Ilumina® 502 Laser Printer
I purchased a new macbook pro with 10.5.7 - Xante AW1200
No on the Xante Support page the Driver is for 8.x-10.4, not for 10.5.
So the latast available is 10.4. You can see it here
Regards.
Jul 28, 2009 | Xante AW 1200 Laser Printer
Xante cl30
If the printer is still under warranty, and a new yellow drum doesn't fix the problem, or if you install a new drum and the problem returns, Xante should provide you with warranty support. This problem can be caused by a defective high voltage power supply, and that is not a user replaceable item.
May 02, 2008 | Xante CL30 HSE Laser Printer
Paper Jam will not clear
  1. I have identical problem with the Xante 1200.
Mar 14, 2008 | Xante AW 1200 Laser Printer
Unable to get Xante printer to work
When I send a job to the printer via Ethernet, nothing happens on the printer. I only get a solid red light. Why?
This is an indication of a media size mismatch. Make sure that the correct media size is set on the tray to which you are printing, and try the job again.
(from http://www.xante.com/support/aw1200/)
John
(Xante ASA)
Nov 19, 2007 | Xante AW 1200 Laser Printer
19 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
