The 2 buttons small and large blink all the time how can I stop this
SOURCE: the small and large cup buttons are alternatly
I had the same problem and was told it needed to be repaired by Nespresso and the cost would be 115 euros.
Testimonial: "Thank you, Yes, Nespresso said that same to me, I didn't have it fixed I could have had a refurbished one for $100 or receive $125 off a new machine. "
SOURCE: When you press the button for a large cup of
You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. The small cup that you are currently getting was probably set at the factory. Good luck
SOURCE: I have a Nespresso Le
I had this problem and took the machine back to Nespresso. They tested and said the machine was fine, but when I got the machine home the lights continued flashing. I called Nespresso and they suggested plugging it into a different power socket - Bingo! Problem solved.
Seems like the Nespresso Cube has some very sensitive power requirements so try this and see if it helps
