Question about Cycling
Looking for CSA Autobike instruction manual
I just bought a autobike classic and would like to find a manual to reference chain tension.
3 Suggested Answers
SOURCE: Looking for CSA Autobike instruction manual
I can supply a Xerox of the manual, SaturnSL21992@Hotmail.com
Posted on Apr 02, 2009
carlsbiz
  • 1124 Answers
SOURCE: CSA Autobike Parts
You might find something here ---
http://www.bikemagic.com/links/links2.asp?Cat=151
Posted on Jul 08, 2009
Can I adjust cam chain tensioners on a 96 Vulcan classic 1500.
Hi, Mike for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Cam Chain Tensioner Extenders
Kawasaki Vulcan 1500 1600 Camchain Tensioner Extender Install
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
1996 Kawasaki Vulcan 1500 Classic Owner Manual
Dec 30, 2016 | 1996 kawasaki VN 1500 Vulcan Classic
I have a autobike classic. I here a clicking when I peddle as if the chain not engaging when it shifts. Derailed seems off centerd? What to do?
The cable adjuster for the D?railleur is not correctly set.
Download the adjustment instructions from the manufacturers website.
Jul 17, 2015 | Cycling
When trying to pedal the bike, the sprocket does not engage, rather the pedals just go around without resistance, or engaging the chain. Everything else seems okay. It has been hanging upside down in my...
You, as the only one of us who can see the bike, need to focus on what is or is not happening to define the problem better. Chains engage gears. If not, maybe the chain fell off. Try web searching "chain fell off" or "chain fell off autobike classic" or any common simple symptom to get a feel for the various reasons it happens.
Aug 09, 2011 | Cycling
I cannot find my manual to my 18v cordless chainsaw ccs818. I need directions for putting the chain back on. I would like to download a copy of the manual.
Your manual can be found here:
http://www.blackanddecker.com/Manuals.aspx with pop-ups enabled then enter your model number
or
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90560838,CCS818.pdf
See the instructions for replacing the chain on page 11. It makes reference to the figures on page 6 so that you know exactly what to remove.
Basically... loosen the bar allen screws. Remove the sprocket cover. Loosen the bar retaining bolts. Use a flat bladed screwdriver on the bar / chain tension screw to shorten the bar enough to install the chain. Then adjust the chain tensioner so that there is just a little slack in the chain at the bottom of bar between the drive sprocket and the bar. Tighten the bar retaining bolts install the cover / tighten all cover fasteners. (see details D and E page 6 of the 2nd link above.)
The steps below are copied from the manual.... I can not undo the formatting and can not post the figures here due to size restrictions..
Thanks for choosing FixYa,
Kelly
Replacing the Saw Chain
CAUTION: Sharp chain. Always wear protective gloves when
handling the chain. The chain is sharp and can cut you when it is
not running.
WARNING: Sharp moving chain. To prevent accidental
operation, insure that battery is disconnected from the tool
before performing the following operations. Failure to do this
could result in serious personal injury.
• Place the saw on a firm surface. Rotate the two allen head screws
(11) counterclockwise with the wrench (13) provided as shown in
figure E.
• To remove the saw chain (9), rotate the tension adjustment screw
(23) in the front of the housing using the flat screwdriver end of the
wrench (13) as shown in figure F. Turning the screw
counterclockwise allows the guide bar to recede and reduces the
tension on the chain so that it may be removed.
• Remove sprocket cover (10) and allen head screws (11).
• Lift the worn saw chain (9) out of the groove in the guide bar (8).
• Place new chain in groove of guide bar making sure saw teeth are
facing correct direction by matching arrow on chain with graphic on
housing shown in figure G.
• Place the saw chain and guide bar assembly around the sprocket
(19). Check to make sure that the slot (20) in the guide bar (8) is
over the two location pins (21) shown in figure E and that the hole
below the slot is located over the adjustment pin (22).
• Replace sprocket cover (10) and thread allen head screws (11) in
with wrench until snug, then back wrench off one full turn.
• Pull bar nose up and keep it up as you adjust tension.
• Rotate the tension adjustment screw (23) in the front of the housing
clockwise to increase the chain tension as in Figure F.
Follow instructions in "Adjusting Chain Tension" section.
• While still holding the bar nose up, securely tighten the rear allen
screw (11) first, then tighten the front allen screw.
• When the chain is new check the tension frequently (after
disconnecting battery) during the first 2 hours of use as a new chain
stretches slightly.
not running.
• With the saw still on a firm surface check the chain tension. The
tension is correct when the chain snaps back after being pulled
1/8 inch (3mm) away from the guide bar (8) with light force from the
middle finger and thumb as shown in figure H. There should be no
"sag" between the guide bar and the chain on the underside as
shown in figure I.
• To adjust saw chain tension, loosen the allen head screws (11).
using the flat screwdriver end of the wrench (13) as shown in
figure F.
• Do not over-tension the chain as this will lead to excessive wear
and will reduce the life of the bar and chain. Overtensioning also
reduces the amount of cuts you will get per battery charge.
• Once chain tension is correct, tighten allen head screws (11).
stretches slightly.
Nov 08, 2010 | Black & Decker Garden
Can i adjust cam chain tensioner in kawasaki EN 500 1992, if not is it possible to fit manual cam chain tensioner.
no, it is automatic adjustment only, once it has reached it's end, you must replace the chain
May 04, 2010 | 1996 kawasaki EN 500 Vulcan Classic
Parts for autobike
This company is now called LandRider
You can contact them at;
http://www.landriderbikes.com/?src=google&gclid=CMnjx8WrsJoCFRAhDQodEkKkbw
May 09, 2009 | Cycling
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
