Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher model GU2400XTPS6 wire schematics
Clean light flashing heat circuit
aborcass
  • 2651 Answers
SOURCE: Whirlpool Dishwasher Model GU2500XTPS1
there s atechsheet / troubleshooter behind you lower kickplate assy-- this was taken from there
PROBLEM: WON’T RUN AND LED ABOVE KEY(S) IS FLASHING
RAPIDLY
Stuck key(s) or shorted
circuit(s) in keypad.
See Checking Keypad Operation, page 1. Shorted circuits or
connections on the control
that read the keys .check/replace keypad
1. Unplug dishwasher or disconnect power.
2. Check/replace control
Posted on Nov 03, 2008
  • 188 Answers
SOURCE: clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
rylee_smith
  • 8619 Answers
SOURCE: Whirlpool dishwasher doesn't clean very well
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 22, 2009
sclarke7
  • 222 Answers
SOURCE: whirlpool dishwasher model number GU3600XTSY2 is
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Posted on Mar 26, 2010
KevinWhite
  • 1902 Answers
SOURCE: The clean light is flashing
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Posted on Feb 17, 2011
My whirlpool dishwasher quiet partner it will run and clean but then it will drain and the red light will come on and it won't heat dry them What do I need to do to fix it
Model # would be nice to instruct hoe to place in diagnostic some models will lock out unable to start if water doesn't heat same heater used for drying there are 3 components in the heating circuit the electronic control, the thermistor and the heating element don't know how mechanically inclined you are or if you know how to use a multimeter if your are provide the full model # I'll pull the schematic and instruct which wires to ohm for the heater.
Feb 08, 2014 | Dishwashers
I have a Whirlpool Gold model number GU2400XTPS6 and the Hi-Limit light keeps flashing 7 times and nothing works
I have replaced the control board and put the dishwasher throught the diagnostics but it still isn't working properly... any suggestions?
Jan 20, 2013 | Whirlpool Dishwashers
The clean light is flashing on a whirlpool dishwasher-model du1048. The manuel says the dishwasher has malfunctioned and to check the heater circuit. How do I do that?
Kevin
Feb 17, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Clean light is flashing du1145 whirlpool dishwasher, will not run
This is a Common Problem. Read the same solution i offered to many Customer's and it actually worked like anything :-
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishawasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 11, 2010 | Whirlpool Dishwashers
Dishwasher will not run clean light keeps blinking
or
Hope i helped you.
Jan 10, 2010 | Whirlpool Dishwashers
Next Step
If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
or
Hope i helped you.
Jan 08, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Clean light flashing 7 times.
or
Hope i helped you.
Jan 06, 2010 | Whirlpool Dishwashers
Our clean light flashes 7 times pauses and flashes 7 times again, we can not restart the unit whats could be wrong
This machine was made by Whirlpool and the flashing clean light is a common error code for them.If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has until all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
or
Hope i helped you.
Dec 30, 2009 | Whirlpool Dishwashers
Clean light flashes, washer won't run
or
Hope i helped you.
Oct 07, 2009 | Whirlpool Dishwashers
Clean light flashes 7 times at a time.
or
Hope i helped you.
Oct 07, 2009 | Kenmore Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
22 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
