Question about Black & Decker 1700 PSI Electric Pressure Washer
Pressure washer runs for 15 minutes then shut off. Overheat?
I have a B&D pressure washer model PW1600 that runs fine for about 15 minutes then shut itself off. I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can be wrong and how can I fix it? Thanks.
2 Suggested Answers
  • 7 Answers
SOURCE: i have a black & decker pressure washer model
check the unloader valve (pressure relief valve) probably need to replace the o-ring. it should be on the side of the pump and have a large spring. just unscrew and replace.
hope this helps.
Posted on Sep 12, 2009
My craftsman pressure washer shut off after 15-20 minutes of running.
Go to http://www.searspartsdirect.com/ Enter your model number to download manual. There is also an option to talk to an expert. http://www.searspartsdirect.com/
Sep 06, 2014 | Garden
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
Pressure washer runs for 15 minutes then shut itself off. Overheating? I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can b
Not enough water VOLUME and pressure to supply the pump with a steady flow of water. Water is cavatating (adding air to the water) and the piston is heating up and jambing. Try using a larger size hose diameter and a shorter hose to supply the pump.
Apr 22, 2014 | Black & Decker 1700 PSI Electric Pressure...
Pressure washer shuts off overheating
If you are using an extension cord this will happen. If using an extension cord make sure it is a 12ga.If you are not using an extension cord then it could be a bad motor or low voltage from the source.
Apr 19, 2014 | PowerStroke 1700 PSI Electric Pressure...
Pressure washer start fine and idles appropriately trigger is depressed washer runs for about five minutes then just shuts off. Engine restarts fine but when trigger is depressed engine shuts off
looks like the fuel cap may not be venting try it with the cap loose allowing air into the tank sounds like lack of fuel entering into the carburetor.
Aug 03, 2013 | Karcher 2500 PSI Pressure Washer
John Deere 3000psi pressure washer stalling
Mine is having the same issue...I googled and found this with no answers. I'll update if I can find a cure on my own...
Have you checked your oil level?? Small engines have a cut-off switch if your oil is low...mine is topped off so this is not the solution for me..but it could possibly for you.
May 01, 2010 | Garden
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
I have a black & decker pressure washer model PW1600 and its not getting the high pressure anymore. any ideas
hope this helps.
Sep 12, 2009 | Black & Decker BDP2600 Gas Powered...
Cord is rapidly "minced" up
PW1600 Black and Decker pressure washer - works for about 15 minutes steadily then quit - will not work again - power - test/reset is o.k. - Help!
Jul 09, 2009 | Black & Decker String Trimmer Cordless 12"...
Excell VR2522 Pressure washer - sudden loss in pressure.
Leaving the engine running for more than two minutes without releasing pressure trigger causes aluminum pump to overheat and causing damage to the purmp, resulting in sudden low pressure. (see page 9 in manual)
Jun 18, 2009 | Karcher 2500 PSI Pressure Washer
Black & Decker 1700 PSI Electric Pressure Washer Logo
76 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
