Question about IBM System x3500 M2 (783932U) Server
Windows xp installation
My Oracle 7.3 does not support windows server 2003 so i need to install windows xp on my ibm x3500 server
  • 596 Answers
if you have the space on a separate disk drive, I wo recommend installing Windows XP on a seperate drive than the server os and create a dull boot server. You would install the XP os as normal. When ask where to install, choose the spare drive other than where the server os is installed. This should allow Oracle to run as you need it.
Good luck
N.I.T.
Posted on Jun 07, 2014
  • 58 Answers
SOURCE: Install windows xp on a IBM xseries 200 8479 computer
You have to download the scsi driver from the ibm site. You'll need a floppy and floppy drive. When you boot with your xp cd to setup press F6 to install driver.
Link to your IBM. Since IBM have different models you have to type it at the provided link.
http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/brandmain?brandind=5000008
good luck
Posted on Dec 21, 2007
tjt3
  • 44 Answers
SOURCE: Raid configuration
When your system boots up you should see an option to access your raid controller if not or if your system doesn't see the controller at all you will have to download the utility software from IBM, but you need to be careful any change you make in the configuration of the disks will delete all data on your drives. This is non-recoverable loss. The utility has help and is fairly easy to understand.
Posted on Mar 24, 2009
falsafat
  • 31 Answers
SOURCE: hard disk no detect in installtion of window
You need to give windows installation the drivers for your Sata-Bus by pressing F6 while the installation load the drivers (like when we want to install on RAID drive). or do the following method follow the links in that page for Slipstreaming VIA Serial ATA drivers and the other link to create a boot CD Creating a bootable Windows CD with Nero.
it's all in the following link: http://weblogs.asp.net/jkey/archive/2005/08/28/423901.aspx
Posted on Apr 12, 2009
  • 105 Answers
SOURCE: new install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
Posted on May 26, 2009
info2u
  • 596 Answers
SOURCE: how to install windows server2003in ibm server x3400
The install is fairly easy. Before you begin make sure if you have SCSI adaptors installed have the drivers for them on hand. If you do not have these drivers you should download them to a 1.4MB floppy disk. When you are ready, put the Windows Server disk in the cd/dvd and reboot the IBM. Follow the instructions on screen and you shoud be fine. From start to finish it should take you about 1 1/2 hours to complete everything.
Good Luck
Franklin
C2Solutions
Posted on Jul 21, 2009
Insert xp cd, follow the setup procedure and that is it ... finish with installing needed drivers.
Apr 23, 2014 | IBM System x3500 M2 (783932U) Server
How can install windows xp
no more supported by microsoft
power off computer
as soon as you hit power button to turn on PC
hit F12
insert cd ....select cd drive their and hit enter
follow instructions
yipeee you have installed win xp
Apr 22, 2014 | IBM System x3500 M2 (783932U) Server
CAN WE INSTALL WINDOWS XP ON IBM x3500
You can but updates are not supported by Microsoft.
Internet explorer will be internet explorer 6 and you can't upgrade it to ie8.
Terry
Apr 10, 2014 | IBM System x3500 M2 (783932U) Server
INSTALL WINDOWS XP ON IBM X3500
Support for Windows Xp has ended 4-12-14
Terry
I want install oracle 8i in windows 7
You can't install that Oracle version directly on a Windows 7 machine, but you should be able to install it on XP Mode.
Oracle 8.1 is not supported on Windows 7. It is never intended to be used on Windows 7. You have to look at virtualisation (Virtual Box, Virtual Pc, WMware), to get Oracle 8i installed on Win XP, 2000, 98.
Mar 31, 2011 | Computers & Internet
Windows 7 installing but windows server 2003 cannot install, hard disk is not support
In order to install Windows 2003 , you need Ibm Server Gide cd . Boot from the cd and follow the wizard
You can download the software from below link
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5087263
Its a image file . So after download burn image to cd and boot from cd.
That' all
Oct 24, 2010 | IBM x3400 Server
Sir, please provide me with the soloution and my problem is that my client have a system which have window 7 and the client is using mstar which runs on oracle 8i and when i install the oracle 8i it is...
I am sorry to say but oracle 8i is not compatible with windows 7. If you would like this to run you would be needing a downgrade to xp. But if you insist on using windows 7 what you could do is install a virtualization software like virtualbox and install windows xp on it and the software you need. So, it would be like running windows xp in windows 7.
Apr 29, 2010 | HP Pavilion a1610n PC Desktop
Windows xp pro oracle 8i database access very slow
check your computer comfiguration check the ram for memory
Nov 28, 2007 | Microsoft Windows XP Professional for PC
Problems with Oracle Applications Installation on ASUS 945 MotherBoard with Intel Dual core 3.0 Ghz Processor
It isn't the motherboard or your PC. Install the latest service pack and security updates for you computer. You didn't say what version of Oracle you are installing.
Jun 26, 2007 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
IBM System x3500 M2 (783932U) Server Logo
102 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
