Question about LG Washing Machines
Wfsl1132et Machine will not fill with water
Machine will try to fill with water and then stop and just trickle out ino washing machine drum.
  • 209 Answers
SOURCE: kenmore washing machine 80 series
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
Posted on Oct 14, 2007
  • 1294 Answers
SOURCE: Bosch WFX Excel
You have to replace the water inlet valve, the valve where water enters your machine.
Posted on Jan 22, 2008
  • 864 Answers
SOURCE: Hot water barely trickles into washing machine
Check the hose at the end where it connects to the washer (the inlet valve unit). There may be a screen there also that needs to be replaced or cleaned. If not then the hot water solenoid valve is probably gunked up with the same type of stuff you found in the filter screen. You may be able to clean it enough to get it to work but replacing it is just as easy and not very expensive. (Even cheaper see if you can salvage one from an old machine at the dump or that someone has left at the curb--the units are very standard across many manufacturers in the tU.S.) Both the hot and cold water valves are in the same unit.
Posted on Jul 23, 2009
Testimonial: "The hot water solenoid valve was the precise problem! Thank you. I told my handy man what the fix likely was and he repaired it for $92. "
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
  • 6277 Answers
SOURCE: LG Turbo drum washing machine
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Posted on Mar 29, 2011
How to get rid of lollies stuck at the bottom of washing machine
Fill Machine with hottest temp you can With some old rags or clothes and run a full cycle. OR boil a kettle and trickle on hot water while levering them from the drum with a blunt knife. Remove any remaining deposits with hot water and a rag then wash as normal. Lollies are only boiled sugars after all
Nov 03, 2014 | Washing Machines
Cold water runs really slow when filling up washer,starts out normal but then goes to just a trickle until filled.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 30, 2011 | Washing Machines
Cold water trickling out.
heatman101
Feb 21, 2011 | Kenmore Washing Machines
The cold water just trickles out.
heatman101
Oct 14, 2010 | Roper RAS8445KQ Top Load Washer
Washer will not fill, water trickles in
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
heatman101
Oct 11, 2010 | Kenmore Washing Machines
The machine will not fill on cold water cycle( only trickles in)
heatman101
Sep 16, 2010 | Kenmore 24032\24036 Top Load Washer
When we use the cold water it is just trickling in. I cleaned the water inlet screen for the cold water on the back of the machine but it is still only a trickle. Is there another screen inside the back...
Often there is a screen at the inlet of the hose also...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water trickles in
you may likely have a faulty water valve or water is back filling through the waste hose if it is plumbed into the sink. also is the supply water pressure low? it may not be assisting the water valve to shut fully.
Jun 07, 2007 | Kenmore Elite 45986 Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
