Question about Boss Car Audio & Video
Boss bv8996b white screen or blue screen saying no signal
18c808 aa subwoofer with amp from Focus. How do I install it?
ask here
http://www.f150forum.com/f75/how-fix-your-subwoofer-amplifier-7l2t-18c808-aa-227544/
or
Diagram 7l2t 18c808 aa - Dual Ford Mustang Convertible 94-12 Boss 12" Phantom Sub Box Ce1250m 1250w Amp
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
Oct 23, 2015 | Ford Cars & Trucks
Hi i have a boss dvd in dash 996b in a 2002 nissan altima....always worked good ..i wired the pink wire to the fram to ground out ...always worked...i open dvd to watch movie and display shows NO VIDEO...
have you tried a different video input such as a video input behind the radio. have you made sure that you are playing dvd and not video in. or the boss unit could be broken.
May 05, 2011 | BOSS AUDIO SYSTEMS Car Audio & Video
I have a VT465 and the projection back ground is yellow and I can't get it to be white
If you are talking about the actual image that is coming from a laptop being yellow instead of white, then this is caused usually by a bad signal cable running between the computer and the projector.
To be more specific: All colours in a projector get made up in some way between red, green and blue. White is all of these colours at maximum, yellow is made by red and green at maximum but no blue. If your image is Yellow when it should be white, then the blue signal information is not reaching the projector. This can also happen within the projector or computer itself but is less likely. If your using a VGA cable (15 pin cable) then blue is run through pins 3 & 7 (positive and negative respectively), see if your cable is either missing these pins on either end or if they are bent, although it's more than likely within the cable itself. You can test this theory easily by trying to put something blue on screen, if the blue signal isn't getting through then it'll appear black.
If changing the cable doesn't solve the problem try testing the computer by trying to use a different one, and test the projector by plugging in a monitor or another projector.
If you are getting a yellow screen without sending signal and just trying to get the "no signal" or "no input" screen white, then this won't be the case.
Mar 24, 2011 | NEC Office Equipment & Supplies
The screen has a box that says : 1:Analog input Self Test Feature Check Red (line across) Green (line across) Blue (line across) White (line across) if you push the menu botton you get a other screen...
The issue is that the monitor in not getting the signal. This tells me that the video adapter ( or on board video) has went bad. Try another video card if all your doing is social media and surfing you can pick one up for around 20.00
Oct 27, 2017 | Dell Computers & Internet
Boss audio bv9150 screen strats to flick then says no video signal
Issue with Reader Carrier... Fail To Read Menu On DVD,
Due To Lens Obstruction... Try Magic DVD Cleaner., It a DVD you insert in Then it clean the lens for you... Sometime it Work Good Luck.
Oct 09, 2010 | BOSS AUDIO SYSTEMS BV9155B Car Video...
Screen says no signal. when i push the input button,tv says no signal not available Stuck on the blue screen, there is NO lock icon on the screen. I have the same problem. I attached the cable from my...
HD TVs do have different cables, I went to Time Warner and swapped my regular box for an HD box, the cable ends are blue red and white, I believe. Also in order for my box to work on the screen I have to switch to "Component" instead of "TV". Hope I helped!
Dec 11, 2008 | Haier HL22R 22 in. LCD TV
Car Audio & Video Logo
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
