Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
I have a switch D-Link model DES-a008d (made in china. I want to connect two pc in one internet line.i need step by step guide.
  • Carl Navarro
    Carl Navarro May 11, 2010
    A 1008D is an 8-port switch. You plug 3 cables into 3 of the 8 ports and those 2 devices are on the network.
    Somehow, I'm guessing there's more to this than that or you wouldn't be here.
    Please tell us the rest of the story. Who is your service provider and what is on the other end of that internet connection?
Do you have a router or modem set up as well?
Posted on Jun 20, 2009
How can I install or connect my d link to the internet line and my computer
I assume you have a broadband connection which you are directly to your computer.
In that case please connect the broadband ethernet cable to one of your switch port.
Get a new CAT5 or CAT6 ethernet straight cable and connect one end to any free port of the DES-1008D 8-Port Ethernet Switch and other end to your Computer.
No configuration needed to be done on DES-1008D 8-Port Ethernet Switch
Best Regards
Nov 20, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
How to connecte d-link switch model-DES-1008D two same switch pls urgent
Sometimes we need to connect 2 switches, which can be done by using Ethernet Cable (CAT5 or 6). Just connect the cable to the LAN ports from one switch to another. Let me know the purpose of doing so that i may guide you better.
Hope this helps!
CreativeTECH
Nov 16, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Getting low or no connectivity error when trying to connect laptop and other devices to 5-port DLINK switch. Lan line going to switch is confirmed working as i'm able to plug the laptop and other devices...
please change the cable which is connecting your laptop to D-Link DES 1005 Ethernet Switch.
This error appears when you have either a bad cable or bad switch or NIC card on Laptop.
As you have Laptop and other devices and getting the same error , so i suspect issue with the cable.
Please use a new Straight LAN cable.
Oct 31, 2010 | D-Link DES 1005 Ethernet Switch
We've got the Dlink DES-1008D setup in our office. Since the past 3 weeks, we've been facing disconnection problems. 5 desktop computers, all new and very recent, are connected to this. We've got an...
Ok, the next time when the disconnection occurs. Try the following:
Open command prompt. And try pinging www.google.com, if the ping is successful and you are still unable to access the internet, then you may want to check the proxy settings on your web broswer, or possibly repair/reinstall the browser. You can also try accessing the internet on a different browser.
If you are unable to ping google successfully, then try to ping the IP address of your wifi modem, this is your default gateway. If you are unable to ping this address successfully, then check the cable from the DES-1008D switch to the wifi modem. As a local area connection 'connected' just shows that the link from your PC to switch is fine.
Please try these steps and let me know the results.
Regards..
Apr 05, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I need to connect dsl to a router then to 9 pc's
connect the router configure the settings give by the internet provider and configure the NAT then u can attach a switch if required and can access....
Dec 29, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
I have a d link DES-1105. cant get more than one computer to work on hub/switch.
Hi!
Unfortunately, hubs or switches cannot be use to share internet access specially if it's connected to a modem. To share internet access, you will need a router. If you prefer not to use a router, you can enable ICS (Internet Connection sharing) on one PC and share internet access to the others. However, the PC that will share internet access will need two ethernet cards (or LAN cards).
Your setup will look like this:
If internet is not a concern, and you just want to connect the computers to share files and resources, you will have to se your computers to static IP. You do not need any additional device - just connect your computers to the hub, setup a static IP on all the computers.
If you need further assistance setting up static IP on the computers, please reply and I'll give you the step by step instruction for that.
For any setup, a router will be the best option.
I hope that helps.
Good luck and have a nice day!
Nov 30, 2008 | Computers & Internet
D-Link DES 1005D
set u r borad band router/modem to dhcp and set both system to auto detect ip address put u r boradband ethernet cable to hub and both pc in same hub that it nothing to do with configure  enjoy!!! need help for router/mode to configure tell me the model number i will tell step by step
Oct 18, 2008 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
2 pc connected but wont allow both on internet at once
Set up both pc's with dhcp. To do this, right click (My Network Places) in the start menu and choose properties. Right click your network connection and again choose properties. Click Internet Protocol (TCP/IP) and then select properties. Choose (Obtain an IP Address Automatically). Then (OK) and again (OK). Do this on both pc's.
Nov 13, 2007 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
184 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
