Question about Roland KC550 Amp Keyboard
Will amp still work after third prong is broke
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 16 Answers
It works, but you will not be protected from static shock, your equipment will not be protected from power surges with high spikes, and most digital equipment , such as digital amplifiers, will have a weird background static noise, 1X Extension Cord Replacement Electrical AC Wall POWER PLUG End Male...
They are fairly cheap, fix it. Good luck
Posted on May 14, 2016
    Champion:
  • 207 Answers
If the third prong is the round one, then that is the ground to your amp. It will still work, however, the amplifier will not be properly grounded. So in a pinch you can use it, but you need to get the cable replaced. The ground wire is there for your safety, in case you plug your amp into a mis-wired outlet or if you are plugging in another instrument like a keyboard, mixer etc. that may be mis-wired. This could lead to a bad shock or worse. You have been warned.
The volume knob on my esteban g10 broke off
There is no other fix than to replace the volume pot. if you are not familar with working on electronics, it will require a trip to the repair shop. Unfortunately, the repair charges will most likely be more than the cost of just replaceing the amp.
Jan 03, 2014 | AMP ESTEBAN AMPLIFIER NEW
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Fender 1270p buzzing, appears to be an internal ground problem
I would never use a fender amp without the ground plug as I have been electrocuted by doing this and could not let go. I will be wireless from now on.
Feb 16, 2013 | Fender 1270p Artist 10" 2-way...
Speaker humms only. what causes that?
Incorrect connections or volume settings.
• In powering up, mixer first then amp
• In turning off , amp first then mixer
If hum still persist, without the mixer connected
then speaker amp may need servicing.
Jul 31, 2012 | Samson Auro D415A Speaker PA Active
I have an epiphone ea7p professional guitar. It has a matching amplifier with a special 6 prong plug for this guitar. I need a new 6 prong plug. I would like to buy the entire cord that connects from...
Amazing guitar!
Unfortunately, I have not been able to find the specialized plug you need. Being 1 out of less than 400, it is doubtful that they are still being made. However; any decent music shop will be able to repair your old plug.
Oct 26, 2010 | Epiphone Les Paul Studio Electric Guitar
I have bought a second hand guitar amplifier, and would like to know, how to do a safety check on it, using a voltmeter or whatever, hank
First and foremost make absolutely sure you know what you are doing. If the amp is in good working order you should be O.K. The biggest safety check you can do is make sure that no one has removed the ground prong from the power cord. If it doesn't have one then you should take the amp to your nearest qualified amp repairman who can do a certified repair on your amp. For instance if it is a Marshall product, take it to a Marshall dealer. This type of repairman not only has the training, tools and schematics to work on your amp he will also be able to tell if someone has done a safe mod to your amp. Not only that he can be held contractually responsible if you are injured through the correct use of the amp after he has done the repair. Read your service agreement carefully before allowing the work. Amplifiers can kill you.
Jul 25, 2010 | Marshall 15 Watt Guitar Amp
The prongs on the USB connector broke off. Do we need to replace a board and if so how do we do so?
You can buy new connector and replace broken one. You need skill at soldering and of course have to open the unit to access the broken connector.
Oct 10, 2009 | M-Audio M Audio Keystation 88es 88 Key USB...
I broke the master volume switch off. How I do I
I have a soloution that will work as long as you still have the metal shaft on it?
if it does go to your local electrical store and buy a new knob.
then all you have to do is screwthe knob back on to the amp.
please reply and tell me if that helps.
Aug 01, 2009 | Line 6 Spider Iii 30
Cable broke off in the input jack
I'm pretty sure t6hat the output jack is a sealed unit(contacts inside soldered to the surface of the circuit board. You may be able to grasp the center shaft of the plug with a thin jawed hemostat or really skinny long nosed pliers and pull it out that way. Make sure the amp is off and unplugged from the wall. If that doesn't work you will either have to get it removed at a shop or disassemble the amp to remove the circuit board and unsolder the jack and replace it or get the broken plug out of the jack once it is unsoldered. I've never had a Line6 apart yet but thats probably the type of jack they used. Thats because it has to be electronically isolated from the chassis. Hope this helps.
May 15, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Fender M-80 electric Guitar Amp.
You might have a ground problem. Does it do it in different outlets or when you take it to someone else's house? One easy solution to ground problems can be running a three prong to two prong adapter on the power cable. Give that a try and see if it helps.
Nov 09, 2008 | Fender Fm25dsp 1x10' Guitar Combo...
Roland KC550 Amp Keyboard Logo
20 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
