Question about HP PSC 2410 All-In-One InkJet Printer
Loud motor sound and green blinking ON light....!!!!
When plugged up, the screen shows an hourglass and HP logo. Blinking ON light. Loud clicking sound. Nothing else. Has to be unplugged. HP 2410 Photosmart All-In-One
    Brigadier General:
  • 4,090 Answers
Clean the cartridge rails and move the cartridge by hand if possible the full length of the rail, turn off, then on to reset. Hope that fixes it for ya
Posted on Jun 20, 2009
How to change c to f on the temple touch thermometer
1. Press and hold the ON/OFF button for 5 seconds - on the screen you will see the hourglass icon blinking and the last measured temperature.
2. Once the last reading showed on the screen disappears, the scale icon (F,C) changes as well.
3. Release the button, the hourglass icon will disappear in 5 seconds and 2 beep sounds are heard, indicating that the device is ready for use
Jan 12, 2018 | Miscellaneous
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Why is the front panel screen HP DesignJet 4020ps plotter show a blank screen with a blinking green light?
According to the manual, a blinking green power light indicates that the unit is transition between off and on.
Dec 30, 2014 | HP DesignJet 4020PS InkJet Plotter Printer
Hp C309n blinking power light
The blinking light indicates there is a malfunction; such as paper jam, cartridge missing or ink cartridge caddy has a problem (ink on bottom, or dryed up, etc; caddy can be pulled out and cleaned), or something you were going to print was not printed due to low on ink, etc. It may show a number that you could contact H/P support, give them model of printer and the error number and they may be able to assist. Actually, blinking light could be a host of problems. Take cartridges out and carefully clean the brass contacts and also on the printer head, clean that too. Edwin, USN-Ret.
Apr 08, 2014 | HEWLETT-PACKARD Photosmart Premium C309n...
Upside down orange light bulb on the right side is blinking. small white logo is also blinking beneath it. It will not print. The print cartridges are new. The are not generic. I have rebooted and un...
When the camera is connected correctly, the Connection light is illuminated. The Connection light blinks green when printing from the camera. If the camera is not PictBridge-compatible or is not in PictBridge mode, the Error light flashes.
Nov 04, 2013 | HP Deskjet 6980 InkJet Photo Printer
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
What's your problem?i have a dell optiplex 755 (tower).. it was working fine.. but one day when switched it on,, it doesnt behave normal.. and no screen was showing on the monitor.. the pc was sho
Welcome to the world of Windows 7. Don't you miss Windows XP? LOL, Windows 7 is a nightmare just like Vista.
Anyway I think it's your Memory. You mentioned moving the memory chips around, but you didn't mention trying one at a time. I think one of them is bad.
Memory ChipRemove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.Try just working with one of them in Slot 1 and swap them out in just Slot 1.
Oh, I just thought of something else, Maybe you have bad Capacitors on the motherboard. Remove the Power Cord, Remove the Case. Take a flash light and look inside the computer at the capacitors. They look like little Battery Towers. If any of them are spewing corrosion out of them, they can cause the computer to go crazy just like yours is doing.
Apr 22, 2012 | Dell Computers & Internet
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
HP LaserJet 1300 is showing blinking of orange light instead of tonner is in
I am having problem in finding solution for HP Laser Jet 1300 which is not getting ready and shows orange light blinking. I have check the tonner and the sensor which are located backside but the problem is still as it.
Apr 11, 2008 | HP LaserJet 1300 Printer
HP PSC 2410 All-In-One InkJet Printer Logo
497 people viewed this question
Seeker5211
Seeker5211
