Question about NEC MultiSync VT440 Multimedia Projector
Green line down the side of the screen nec vt 440
3 Suggested Answers
Marrie
  • 563 Answers
SOURCE: NEC LT170 diplays annoying line
Hi there
This is a common Mainboard failure - you'll have to get this repaired or replaced !
Must warn you that this is quite expensive
Posted on Apr 02, 2008
  • 157 Answers
SOURCE: NEC VT 440 Projector noise
The unit needs to be opened and have the fan checked. If it is out of warranty and you are capable you should be able to access the fan quite easily. It may be rubbing against something or it may have contaminants inside and needs to be replaced.
Posted on Aug 31, 2009
How do I fix a vertical line on a 50 inch nec plasma monitor
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 28, 2016 | NEC Televison & Video
GREEN GLOW on NEC VT 770 projector
That will be a worn or damaged green LCD unit. If still available, extremely expensive.
Jun 22, 2017 | NEC VT770 Multimedia Projector
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
Pink cast in images from NEC VT540/440 projector
Sounds like one of those problems only cureable with expert knowledge of for example Chroma feed , Lcd function , lamp luminence, not to be a killjoy but it sounds like this is one for the engineers an estimate should be free and even if you dont have it fixed you'll know whats wrong if you want to do it yourself providing you have adequate training of course .... Regards vortash
May 08, 2009 | NEC Office Equipment & Supplies
Jan 25, 2009 | NEC VT47 Multimedia Projector
NEC VT 640 projector not getting on
Hi there
Have you changed the lamp yet , or checked the lamp for any marks or discolouration ?
Apr 09, 2008 | Office Equipment & Supplies
Nec vt 675 projector
Hi there
Simply go into the menu and flip it back in the subfolder that will either read Mirror or Horisontal / Vertical Positioning
Lamp not lighting
Reset the lamp and try it.
Mar 28, 2008 | NEC VT660 Multimedia Projector
HItach cp-s860 problem
I have the same Hitachi CP-S860 and have found the problem is with the convergence on the left and right sides of the picture. The one I am working on has a bad ghosting problem also - you can really see the ghosting when the MENU is on the screen. The center convergence is OK. Following Pics show Circle / Cross pattern - 1st pic the red, green and blue are turned on - 2nd pic shows green and blue on only. I do not have the service manual for this set so I do not know the convergence procedure on this one. I have mostly been repairing NEC, Sanyo, Panasonic and Christie LCD & DLP Projectors.
Feb 29, 2008 | Hitachi CP-S860 Multimedia Projector
Nec plasmasync 4200w 3 vertical lines one yellow two purple
Sorry to tell you, it is not a scratch, but a bad cable connection from the driver IC's, connecting up the plasma screen to the drive board, or the drive IC for that section of the screen is defective. It is not a repair a user can do as there are no user replaceable parts inside this set. Your going to have to call NEC or an experienced Plasma repair shop.
Oct 07, 2006 | NEC PlasmaSync PX-42VM2A Television
NEC MultiSync VT440 Multimedia Projector Logo
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
