Question about Toshiba E-Studio 456 Copier
Set default dpi
Change default dpi setting
How do I change the dpi settings on my thermal take mouse?
The buttons on the top(under the scroll) are default for changing DPI. If you can't change DPI from them, install the software for your mouse and open it. You can customise your DPI from there.
Jul 24, 2014 | Thermaltake Tt eSports Element Gaming...
My pictures are only 72 DPI. How can I change the resolution to higher quality?
The dots per inch setting (DPI) is meaningful only when printing the picture. As such, the camera simply fills in a default value of 72. You can change it in Photoshop or any other photo editing program. The resolution setting on the camera only changes the number of pixels in the picture, not how you print it.
Feb 16, 2012 | Casio Exilim EX-S12 Digital Camera
Could you tell me how to find the dpi specifications and settings therefore on my sony cybershot 10.2 MP dsc wx1 ? thanx a lot robert Albers
DPI (dots-per-inch) is an irrelevant setting as far as the camera is concerned. The camera puts in a default value only because the image file has a field for it, and there is no way of changing this default value on the camera.
DPI is used by printers when printing a photograph. You can set it indirectly when you specify the print size. Some printing programs will let you set it directly, and then that will control the size of the print.
Mar 20, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
Sir hw can set my dpi setting i can change dis due to this reason my font size wii be long nd if i was triyin to bring default then its is nt possiple by me so give me solution how can set as default my...
Hi skyabhi_cold, to change the {DPI Settings}.
Right click on a 'empty area of the "Desktop" screen.
paul7of9_183.jpg Select the "Personalize" shortcut when the window open!"
Next, in the [right column] "Tasks" area.
Click on the "Adjust font size (DPI)."
Now, click on the Default scale {Radio Button}.
_987.jpg "You can also make "Adjustments to Customize the {DPI}."
_989.jpg "Drag the "Ruler" for (Pecentage size = 100% < 75%...}.
Click on the "Apply, and OK buttons; when finished!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 16, 2011 | Computers & Internet
How to adjust the resolution to 300 DPI on an
If you are scanning, you should be able to set the resolution (DPI x DPI) in the scanner configuration. If it is blurry, it could be that the default scan resolution is lower (10 dpi or even 75 dpi).
Settings location will depend on the scanner and software used.
Best scan at an equal (300 dpi) or even higher resolution, so you can scale the image afterwards without quality loss.
Apr 23, 2010 | Microsoft Windows XP Home Edition
Changed dpi setting
when was the last time it worked?...Right-click anywhere on the desktop, select properties, settings, display and make sure you have selected the correct monitor display. are you running xp?.
let me know
Apr 09, 2009 | Acer Aspire 5920-6727 Notebook
Adjust font size DPI to make default as 120 DPI
go to settings and set the display settings .
Jan 16, 2009 | HP 2133 Notebook PC
How do I increase the dpi setting on my Olympus D-425?
Unfortunately most of the Olympus cameras shoot at 72 dpi by default - a suggestion is to shoot at the highest quality setting and then use Adobe Photoshop to modify to 200 dpi if that's what you need.
Nov 23, 2008 | Olympus Camedia D-425 / C-170 Digital...
Toshiba E-Studio 456 Copier Logo
15 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
