Question about Goldstar Microwave Ovens
Lg-p930 touch screen not working - Goldstar Microwave Ovens
Hi my LG intellowave's on/off doesn't want to work , all the lights and timer work ,can this be the touchpad
It can be the touch pad.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | LG Microwave Ovens
My microwave LG MB-2341BR is not functioning as the touch panel not working. The start touch is not working. Do we get touch panel replacement now?
I being an experienced technician all I do is get micro buttons such as used in television set .I carefully apply minimal hot air from a hair dyer to the touch panel in a clean environment then strip the adhesive touch panel to check the wire ring that tress back to the pcb that is just beneath the touch panel. yo have to locate common and the wire responsible for touch, then drill a small hole where the micro button will sit solder to wires on the button then carefully solder them on the board.now make sure the button is on the same level with the surface before you return the adhesive touch panel make sure the button sits well then from beneath apply hot glue please don't use super glue if you don't understand I will send you pictures.
Jun 16, 2016 | LG Microwave Ovens
Our lg stainless steel overthe range microwave oven will not start. When pressing start only says power 100
The touch pad could be the problem. Touch pads are notorious for going bade. the door interlock switches could also be a problem. Check to see if all the pads work if they do it could be just the start pad that is bad.
Mar 14, 2015 | LG Over-the-Range Microwave
How do I reset the lg microwave. It's asking reset date but my touch screen
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Jan 07, 2015 | LG LMV1630ST Microwave Oven
What's your problemPvm2070sm1ss ? touch screen control panel intermittently stops working
The touch screen has built in semiconductors that sometimes become intermittent, the only solution is to replace the touch screen.
May 17, 2012 | GE Microwave Ovens
Touch pad doesn't work LMVM1945SB Microwave
that would be for a technician only........ electronic parts of that type are not generally self repair nor readily available
Sep 20, 2009 | LG LMVM1935 Convection/Microwave Oven
Microwave Ovens Logo
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
