Question about Home
My galaxy aqua 3000 shower has lost water pressure
4 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: Very loww water pressure when taking a shower,
It could be debris in the cartridge at the tap itself. Whther 2 cartidges or 1 , it wouldn't be uncommon for those to clog up as well, and it really doesn't take much to cause a decrease in flow. Turn water off to tap(s) and remove handles, then cartridges in behind with proper socket or wrench and inspect for debris inside hole cartridge came out of, as well as the cartridge.
Posted on Dec 29, 2009
  • 11 Answers
SOURCE: sometimes there is no water pressure in the
check filter. could be clogged
Posted on May 20, 2010
  • 3 Answers
SOURCE: Since we changed from a pumped gravity fed to a
One possible reason is you have reversed the hot and cold supply pipes in the process
Posted on Dec 21, 2014
Shower head keeps dripping water does not stop when turned off
I would look into possible failure of the solenoid valve assembly or the valve top assembly, which are parts 8 and 7 respectively, on the linked page. This site also has all the spare parts for sale.
You are viewing shower spares for Galaxy Aqua 2000 Aqua 2000
Aug 16, 2014 | Galaxy Aqua 2000
I have power and water to shower but no water coming through when its switched on
there are two micra switches .contact switches. one is faulty.
Jun 04, 2014 | Galaxy Aqua 2000
Thermostatic valve does not turn
followt this steps and fix it. God bless you
  1. Turn off the water supply and open the faucet handle to relieve water pressure.
  2. Carefully pry off the trim cap with a small screwdriver or putty knife.
  3. Remove the locknut with an adjustable wrench, then lift the spindle out of the faucet.
  4. As needed, remove and replace the O-ring. Before reinstalling, coat the stem lightly with plumber's grease.
  5. As needed, remove the retaining screw and pry out the washer. Install an exact-replacement washer and tighten it.
  6. As needed, inspect the seat and replace if damaged.
  7. Install the valve and tighten, then reinstall the handle and test.
Nov 28, 2013 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
My galaxy aqua 2000 shower has started to cut out the last 2 after 10 mins. I'll turn it off n leave it for 10 mins ten turn it back on then it will happen again. I've taken the head off n
my Galaxy Aqua 2000 Electric Shower keeps running (cold water) even after swithing power OFF it used to completely shut down b4..what should I do 2 rectify the problem ...Please advise.... Thanks a bunch
Oct 18, 2012 | Galaxy Aqua 2000
30 amp fuse blown twice in 3 days why?
If for shower should be 45 amp
Sep 21, 2012 | Galaxy Aqua 2000
Lost water pressure on house
it is normal to loose pressure from the filter it must have very small holes in it for the water to pass threw so it can trap dirt and particales from both well and city water. it is normal for it to cut back on pressure, it will cut back more and more as it catches the things that you are filtering out. what you might want to do is filter your drinking water only, under your sink .dont try shower and outside faucets. and you wont have to replace it as often. well good luck and good day to you... sawdust46
Jul 03, 2009 | House Brand Aqua-Pure AP102T Whole House...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
