Question about HP Business InkJet 2800 Printer
PROBLEM WITH TRAY2
TRAY2 NOT WORK
Konica Minolta Magicolor 4690MF I have a caution error tray2 open close tray2 can someone help close tray2
Check the sensor for tray #2. Another remove the tray #2 check for broken acturator and or broken tabs that go into the machine to indicate the printer draw two is closed. Lift the printer off tray two use just one and bypass does that work eliminates the circuit board of the machine.
Nov 30, 2015 | Konica Minolta Magicolor 4690MF...
I have (caution) tray2 open close tray2 can you help to close tray2
sir Check the sensor for tray #2. Another remove the tray #2 check for broken acturator and or broken tabs that go into the machine to indicate the printer draw two is closed. Lift the printer off tray two use just one and bypass does that work eliminates the circuit board of the machine.
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Aug 01, 2012 | HP LaserJet P2055d Printer
Manual feed tray bypass
Jul 25, 2012 | HP LaserJet 4250n Printer
Printer indicates error 5.0
Replace paper pick up roller tray2.. take out tray2 cassette, you can see the pick up roller..un lock both side lock to take out the roller..if no part avail remove roller Tyre, re-fix in different angle..
Jun 07, 2011 | HP LaserJet P3005n Printer
IBM Infoprint 1532 Tray Selection
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Feb 24, 2009 | IBM Infoprint 1532 Laser Printer
Tray2 Paper emty message after swapping out tray2 pickup roller
Your problem is more than likely that the sensor lever is not properly positioned. You may also have dislodged the shaft from the drive gears (gears on right out side of carriage). Both are easy to do.
Here's a couple pictures of the exact positioning of the paper sensor positioning. It should freely flip up and fall back down with gravity. Remove the tray and check the flag that hangs down.
Just in case you have dislodged the shaft from the geartrain, here's a free copy of the HP Service manual for the printer that will walk you through disassembling the right side for re-mounting the shaft and holder clip for the shaft.
Hope that helps you. :)
If this resolves the issue, hit me with a Fixya! If not ask me further and I'll try and help you some more.
Sep 05, 2008 | HP LaserJet 2300 Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
HP Business InkJet 2800 Printer Logo
18 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
