Question about Microsoft Computers & Internet
Hi .. my dvd drive not detecting any cd or dvd wat to do?? aow reinstall bcos its not detecting any cd
    Problem Solver:
  • 5 Answers
If you have only one drive, make sure that it is connected at the end of secondary ribbon cable of the motherboard and make sure that the jumper is set to master. If it still dosen't work you may have to write down the make and model of the cd drive and download a driver, also make sure that it is identified in the system bios on the secondary IDE channel. Another thing you could try, depending on your O/S, XP for example. Go into control-panel+system+devices+"selected drive"+update driver. In some cases, depending on your system, you may have to save the device to a floppy & install it in DOS
Posted on Jun 20, 2009
Computer doesnt detect drive
Not exactly The computer detects the drive but windows does not detect the driver. Uninstall the drive in the Device Manager and Restart the computer. This will reinstall the driver..
Nov 29, 2013 | Panasonic (CF-VDRRT1M) CD-RW/DVD-ROM...
Dvd drive detection problem
click start Control panel administrative tools computer management device manager scroll to cd/dvd rom drives + to expand could be a yellow question or exclamation mark ? ! or a red X right click update drivers
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
to check the registry
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Feb 19, 2012 | Computers & Internet
My lg dvd writer cannot recognize any discs. wat might be the problem?
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 07, 2011 | LG GSA-H55N DVD-RAM Burner
My computer has detecting cd rom but cd is not detecting
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 22, 2011 | LG Computers & Internet
Acer 4520 cd/dvd driver problem
Try to use another DVD. you told you tried you old DVD from your toshiba. maybe is not compatible.. try in another.. then use your DVD in another laptop if the same from problem.check your board and DVD connection...if this under warranty bring to warranty..
if in Bios also can not detect this is hardware problem...
May 28, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Optiarc dvd rw ad-7560A ATA device won't play cd or DVD
delete the existing drivers and re-install drivers by downloading from official site of your laptop/desktop
restart and it should help you ...letme know wat happens
harish
Feb 19, 2009 | Computers & Internet
LG DVD RW drive not detecting DVD/CD
Start the Run Command Prompt
Type in "regedit" without the parrenthesis then click ok
Go to HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters.... (if lower filter is not there then leave it)
RESTART YOUR COMPUTER THEN THERE YA GO!!!! HOPE THIS HELPS
Feb 02, 2009 | LG GSA-4082BI DVD±RW Burner
DVD +R
Right Click My Computer
Click properties
Find and click the hardware Tab
Click The Device Manager Button
This will bring up the device manager in a new window , from here locate your DVD Drive under : DVD/CD ROM Drives
Click the plus sign next to it and the installed CD / DVD Devices will be shown
To uninstall the CD / DVD Rom Right click on it and choose uninstall
To Reinstall Reboot , and Windows Will Automatically Detect The CD-Rom Drive and install it for you
Aug 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Not detecting
Dear dhavu,
me too have the same problem with samsung dvd combo drive.. no medicine fo it....
Jan 21, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Cdrom not detecting
attach another drive to your system boot your system with bootable windows cd and make your system drive c
install windows in c drive
this problem is incounter
when u install the window in other drive than c
Dec 22, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
