Question about Olympus EVOLT E-500 Digital Camera
Olympus evolt 500 - Flash won't pop up
My camera was working just fine and now my flash won't pop up. I have tried it in all of the shooting modes to see if I could get it to pop up automatically and none work. I also tried it in manual mode and tried to push the button on the back of the camera and it still won't pop up.
    Problem Solver:
  • 15 Answers
Did you have the auto pop up in the menu on?
Posted on Jun 29, 2009
When take picture a flashing green light appears on display
Check that batteries are fresh. Check that camera hasn't been set for no-flash mode.
Give the flash time to charge before pressing shutter.
Aug 21, 2013 | Olympus EVOLT E-500 Digital Camera
How do you synchronize a non olympus flash unit to an olympus e 500
Install flash on hot shoe and use shutter speed on camera set to no faster than 1/125. Read the owners manul for flash AND camera. Be careful, some trigger voltages may be higher than what your cdamera can handle and may ruin internal flash usage, if not camera itself. better to use a Wein Safesynch hot shoe. This mounts ion hotshoe of camera and flash is attached to this.
Dec 30, 2010 | Olympus EVOLT E-500 Digital Camera
Internal flash not working on olympus e500
The Xenon flash tube in modern strobes rarely 'burns out'. I would guess that a switch that is activated when the flash pops up is not working properly. More info can be found here: http://forums.steves-digicams.com/olympus-dslr/159660-e-500-built-flash-not-working.html
Dec 08, 2009 | Olympus EVOLT E-500 Digital Camera
Why won't the flash on my e500 pop up when the correct button is pressed or when I try to take a picture that requires a flash?
When you take pictures in AUTO, Portrait, Macro or Night scene mode, the built-in flash will automatically pop up in low-light or backlit conditions. If you want to control the flash pop-up, set this function to OFF.
1 Menu [AUTO POP UP]
2 Use control dial to select [ON] or [OFF].
3 Press the Ok
button.
If you are in any other mode the flash will not auto pop up.
Apr 16, 2009 | Olympus EVOLT E-500 Digital Camera
Olympus E-500 - Flash not working at all
you will need to try to reset the camera first through the camera menu by placing the camera mode to P, press menu, right arrow to card, down one to custom reset, right arrow, ok, yes to reset. else you will need to send to repair center
Oct 06, 2008 | Olympus EVOLT E-500 Digital Camera
Olympus E-500 flash smelling like burnt plastic
You should contact Olympus about this.
Olympus have had a recall on some older 35mm film cameras for problems with the flash circuit.
Please see -
Olympus Recall
http://www.olympusamerica.com/cpg_section/cpg_recall.asp
Hope this helps,
Vincent
Jul 08, 2008 | Olympus EVOLT E-500 Digital Camera
Olympus e500 internal flash not working
try resetting the camera back to factory defaults by putting camera in P mode, menu, custom reset
Jun 08, 2008 | Olympus EVOLT E-500 Digital Camera
Blurry and out of focus
Hey ammarhazem,
What is most likely the cause of your blurry pictures is that the on camera flash is not powerful enough to provide light coverage to your subject and the movement of your subject is causing the blurry images. Another problem I see is that you are shooting in Program mode, because in program mode you should have no control over the aperture and if your subject is far away and you are using the on camera flash you would want as wide of an aperture as you can get. I would shoot in aperture priority where you can choose the aperture and the camera sets the shutter for you and I would also invest in a more powerful hotshoe mounted flash. In regards to your red eye problem it is probably due to the distance of your subject from the flash also. How red eye reduction works is the flash fires a # of times prior to the exposure to shrink the pupils so the flash doesn't reflect of the subjects retina which produces the red eye problem. A hotshoe mounted flash would also solve this problem because the angle of the flash would not be as parallel to the lens as the on camera flash would be. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 29, 2008 | Olympus EVOLT E-500 Digital Camera
Olympus evolt 410 flash
I have the Olympus e-410 and I cant get the pictures to upload to my PC. I have connected it and have gone into easy print and normally that works. I have even had to turn the camera off and on a few times and then it will kick in but it wont do any of that this time. I cant find the manual and it was my husbands camera before we got married and he only upload once before that. HELP!
Jan 03, 2008 | Olympus EVOLT E-410 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
209 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
