Question about Kitchen Ranges
Wind comes through island hood
On windy cold days, I feel a draft coming through the hood, to the point that last winter I taped heavy plastic over the bottom and did not use it.
  • 3 more comments
  • Anonymous Dec 16, 2007
    on windy days hood dampers open and close making annoying noise.looked up into hood but see no access to dampers.
  • manitar Jan 04, 2008
    I Have a Gaggenau model AH400701 and have back draft issues on cold days. the damper keeps getting stuck open, I would like to know if the manufacturer has a fix for the back draft.
  • Elisa26 Feb 11, 2008
    Our new Vent-a-hood consistently feels very drafty, not just on windy days, but on cold days too. We've had to put cardboard over the vents when not in use. But air still comes through the lights and around the perimeter.
  • Anonymous Feb 24, 2008
    Same problem, spend thousands on meeting building regs around insulation then have to put a dirty great hole in the wall for the extractor flu. V Frustrating. I wonder if anyone sells an automated device for opening and closing the flu off when the extractor fires up?
  • tuff2pass Oct 22, 2008
    On windy days I have the same problem it drives me nuts. Is anything out ther that has a rubber seal around it.
    Sergeant:
  • 288 Answers
Thee is supposed to be a damper in the vent pipe were it connects to the hood. maybe its missing or stuck.
Posted on Nov 04, 2007
I find that if you turn the fan on low during the wind storm the fan holds the damper open so it doesn't bang.
Posted on Dec 25, 2007
I have the same problem. I think installing a damper in the vent pipe somewhere will stop the back-draft.
Posted on Dec 10, 2007
Combustion switch error on windy days
check gas pressure and flame sensor
Jan 06, 2018 | Coleman Heating & Cooling
We have a Bosch AQ125BNG gas water heater. The pilot goes out in the middle of taking a shower and has to be relit. We have had this problem for a couple of years, but it only happens during winter months...
The problem is excessive down draft or condensation. Air flow is important in combustion appliances. Too much airflow down the chimney can blow the pilot out. This is readily apparent when it gets cold and there is air rushing down the chimney in the winter. There may be an air leak in the room with the water heater. While there should be a combustion air supply that is sufficient, there should not be a place for the air coming down the cold chimney to go. That would eliminate the draft. Another thing is if a furnace is in the same room and does not have enough air to supply the burners. IF it is an older furnace without a combustion exhaust fan or has its own flue, the air being drawn into the furnace burners may be blowing the pilot out. Last but not least is the condensation issue. When cold water enters the tank it can cause water to condensate on the outside and drip down into the burner and put the pilot out.
Jan 29, 2018 | Bosch AquaStar Indoor Natural Gas Tankless...
Pilot light on Intertherm MG 075A furnace will not stay lite on windy days. Worked fine for 20 years but has been a problem the last couple of winters. thermocoupler has been replaced a couple of ti
If this really is a thermocouple unit with a standing pilot, it must be pre 1978, I would suspect a crack in the exchanger first off as thats potentially lethal, not a joke, many heart attacks, headaches, fibromyalgia etc comes from undiagosed carbon monoxide exposures!
And many die from it sadly as it is 100% preventable, a detector would be advised even if you are ok there. A draft can be from the roof car ruting out or misssing? any dryer, Jennair, bath fan, water heater, stove top and many hvac systems create negative pressure in the home by exhausting air and not returning any or less than removed, as in a leaky supply duct leaking in the attic, the furnace pulls X cfm and returns Z
and fireplaces etc will backdraft. gas valves do get tired too.
Oct 31, 2012 | Dayton Gas Furnace Heater
Seems to be a draft coming in the passenger door - the carpet seems to coming away from the door edge. Would this be causing the draft?
Thanks for choosing FixYa and welcome to the site. If the door is off just a little bit, it can cause a draft. Also, if the window rubber seal is broke or loose, it can cause a draft. Make sure it is not coming from the engine. Some heat and wind can come from under the dash because of the motor. If you have any questions, feel free to ask and thanks for using FixYa.
Apr 01, 2011 | 2004 Ford Focus
Driver side door on '95 monte carlo will not latch/shut. I live in central MN, last night was cold, windy, advisories were out ...i dont believe there is anything in way, just seem like door isnt lining up...
TRY SPRAYING SOME WD-40 ON THE LATCH! MN DOES GET EXTREMELY COLD IN THE WINTER! MOISTURE CAN GET IN THE LATCHES, AND CAUSE THEM TO STICK! IT IS RECOMMENDED TO SPRAY A LUBRICANT LIKE WD-40 IN ALL LATCHES (I.E. HOOD, DOORS, AND TRUNK, TO KEEP THEM FREE OF RUST, AND DEBRIS!
Mar 12, 2011 | 1995 Chevrolet Monte Carlo
When it get's really windy our pilot light get's blown out, we have a mobile home and want to know if the chimney should be raised
That's certainly a possibility, and there are caps/baffles you can add to the top that may divert wind as well.
But are you certain it's wind coming down the pipe? Make sure you don't have any other drafts that are making it into the unit at another location. If it's really windy and you cover the top does the flame still flicker at all? You might want to check that before you put in time and expense on raising the height and/or adding a rain/wind difuser on top... just to make sure. I lived in a mobile home a time or two, and they're notorious for those little gaps and leaks.
8^)
Jan 03, 2011 | Heating & Cooling
I have a whistle or humming noise from the front of 05 Montana.
Put wide tape on different areas of the windshield edge as a test to see if the noise changes.Then you may know where the noise originates and can correct the noise.
Just by chance,it is a wind noise? and not a front wheel bearing going bad?which is common on these vehicles and can create a humming at different speeds.Next time when the hum shows up turn the steering wheel slightly left and right at road speed and if you can change the hum,it's 99% a wheel bearing.
Apr 02, 2017 | 2001 Pontiac Montana
Noise from dash or windshield
I have the same problem I think it's the rubber flaps that cover the hood hinges, when the wind catches them they flap up and down it I have noticed it seems to be worse on a windy day.
Feb 08, 2009 | 2004 Chevrolet Silverado
Downdraft
I would double check that the installer used the correct vent hood outside. The correct one has a spring that keeps the outdoor flap closed when not in use. Cleaning the outdoor flap area may also help it seal a little better. Even if the right hood was installed, you might check to see there is a spring present (or signs that there was one.
I have never had air blow out the downdraft, but I do feel cold travel to the fan unit which makes the floor cold in front of the range.
Jul 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
707 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
