Question about Epson STYLUS R230 InkJet Photo Printer
Epson stylus r230 printer
Black color is not printing properly on nozzles check page and its look like breaking lines
    Brigadier General:
  • 4,090 Answers
The jet is clogged... set the self clean mode on if this does not fix it try another cartridge. if you have been using refilled, recycled cartridges this may have damaged the jets. common fault that recyclers know about but dont give a toss. ink should be filtered 9 times before being injected into cartridge most recyled are filtered once. this causes jets to become blocked, overheat and actually melt
Posted on Jun 20, 2009
  • dennis bullard Jun 20, 2009
    the jet is clogged... set the self clean mode on if this does not fix it try another cartridge. if you have been using refilled, recycled cartridges this may have damaged the jets. common fault that recyclers know about but dont give a toss. ink should be filtered 9 times before being injected into cartridge most recyled are filtered once. this causes jets to become blocked, overheat and actually melt
Posted on Mar 19, 2010
Hi Experts, I've have clog print head for the black color. Did a nozzle check black doesnt print, did several head cleaning still did not help. Now using cleaning solution to solve the print...
Is your colour ink come out when you print nozzle? If yes, your printer head is alive. In this setuation you should push some alcohole cleaner through plustic seringe several time. If no, there is a trouble in your printer's main board. replace the main board or repair it by a repair man.
Thank you.
Dec 28, 2010 | Epson STYLUS R230 InkJet Photo Printer
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Black ink jet doesn't print
if your black ink does not print, there is a possibility that the nozzle of your printer are clogged by dried inks, to print a nozzle check. turn off the printer then press and hold the paper (middle) and power buttons together for 3 seconds then release. it should feed the paper and print a nozzle check pattern. if the black lines are full of gaps or breaks in the line. you need to do head cleaning to remove the clogs, press and hold the ink button (teardrop) for 3 seconds, wait until the power (green )light stopped flashing. turn the printer off then print a nozzle check again. just repeat the head cleaning process until the black pattern is ok, as well as the other colors. all shld. be complete.
then print
Feb 11, 2010 | Epson Stylus Photo R200 InkJet Printer
Have an Epsom stylus color 440. will not print
I'm trying to do a print nozzle check on my Epson Stylus Color 440 printer that I have but a pop-up box say "Error, can't print". Why is this?
Oct 06, 2009 | Epson Stylus Color 440 InkJet Printer
MY PROBLEM IS MY 230 PRINTER VERTICAL PRINT IS NOT
I have problem while printing colour photos and I would like to know how to print back to back i.e. even and odd pages
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Aug 25, 2008 | Epson Stylus Photo R800 InkJet Printer
Epson Stylus R230 Light Magenta Not working
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
Jun 12, 2008 | Epson Stylus Photo R300 InkJet Printer
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson STYLUS R230 InkJet Photo Printer Logo
500 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
