Question about Zebra GX430t Thermal Printer
No pff response from the printer server - Zebra GX430t Thermal Printer
Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the server... [PASSED] [VIP Raw] Receiving response... [FAILED] *** ...
sometimes YM is very busy for connecting people..that is why you are unable to connect but try reconnecting again...it works
be sure your password and username is correct and your internet connection is stable...
Jun 27, 2011 | Yahoo Messenger
Program error: polytrn map not specified -give me te solution for this pls..
The "polytrn color map" is a component of the terrain that makes up part of the Irene map and is packed into the localres.pff file in the BHD directory. If it's missing, it means the game hasn't installed properly for one reason or another. So uninstall / reinstall it again and then run the ingame update feature before trying to join the Irene server again.
May 05, 2011 | NovaLogic Delta Force V: Black Hawk Down...
I have doubt purchasing HP CP3525n LaserJet printer. Can I connect this printer directly to my Linksys SR224 switch with its built-in jetdirect? Or I need to purchase a print server before it can be...
Hello You can connect yo printer with the router, because it has the capability to connect with network , no need to purchase print server,
if you have heavy load of printing over it then print server is necessary.
Good luck
do rate if helped
Dec 02, 2010 | HP CP3525N Color LaserJet Printer
Cant sign into yahoo messenger. Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the server... [PASSED] [VIP Raw]...
[VIP Raw] Receiving response... [PASSED]
[VIP Raw] Checking HTTP response code... [PASSED]
[VIP Raw] Parsing connection server IP address... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.186.241... [PASSED]
[VIP Raw] PASSED *** 98.136.48.85 ***
Checking connection servers...
[CS Raw] Connecting to connection server port '5050'... [PASSED]
[CS Raw] Sending port check command... [PASSED]
[CS Raw] PASSED
Checking login servers...
[Login] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0001' ***
Aug 10, 2010 | Yahoo Messenger
X3550 All-In-One Printer: Can this printer be converted to wireless?...
yes you need wireless print server device and plug the printer cable to print server and start using by configuirng print router.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
May 18, 2010 | Lexmark X3550 All-In-One Printer
Scan to email gives server response error in home network. SMTP server tried by IP address and DNS name. Port 25 Authorisation POP for SMTP. The other authorisation types give a network error straight...
I've just discovered that Ricoh's built in software only works if your SMTP server sends out without picking up password or authentication.
Having same issue and it worked fine when it was behind corporate firewall with the same connection settings (IP address) as the SMTP server.
Once I changed web hosting - it won't recognize the SMTP server or any authentication methods. According to IKON (Ricoh support for the USA) - your SMTP server has to have "relay exception"
Feb 20, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Hp lj 1200
How much Price HP lj 1200 at Sisney- Astralia?
Aug 16, 2008 | HP LaserJet 1200 Printer
Zebra GX430t Thermal Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
