Question about Mongoose 2013 Crossway 150 Hybrid Bike With 10% Free Goods Medium
Bike weight The total weight of the bike
Rear axle broke in half and was replaced under warrantee.
I am not familiar with this model of bike. I guess there are two possible reasons:
1. The axle was internally weak. It may be either due to its small diameter in the centre area or faults in the metal body.
2. The load was too heavy. Depend on the weight of the rider or any additional people or goods on the bike, the total load may exceed the load limit and the axle broke.
Apr 25, 2015 | Schwinn Meridian Adult 26-Inch 3-Wheel...
What is the total weight -- I need to get a rack.
Racks are available at the nearest bike shop. They can put them on also
Mar 13, 2015 | Huffy 26 in. Cranbrook Cruiser Bike
Will my class 1 hitch support a hitch mounted bike rack and bikes?
perhaps. It is always best to check with the manufacturer of the bike rack you will be using. Some manufacturers do not recommend the use of their racks with class 1 hitches. Those that have bike racks to work with class 1 hitches typically have very specific weights, specifications, and may even limit the number of bikes allowable. Just remember, when calculating the weight of your load don't forget to add in the weight of the bike rack itself. B&W Trailer hitches are great for this job.
Mar 25, 2013 | Chrysler Town and Country Cars & Trucks
Hi guys, my bike keeps cutting out if i put lights on or press the brakes front or rear. bike starts and idles fine. totally stumped and any help would be great
  1. Yamaha Fazer Engine and Transmission
    • The 1998 Fazer is powered by a four-stroke, 16-valve, in-line, four-cylinder engine with displacement measuring 36.55-cubic inches. This motor generates 95 horsepower at 11,500 rpm and 45.0 foot-pounds of torque at 9,500 rpm. It has a six-speed transmission and a liquid cooling system. The 1998 Fazer has a top speed of 139.8 mph.
    Yamaha Fazer Brakes, Weight and Fuel Capacity
    • The 1998 Fazer has dual-disc front brakes and single-disc rear brakes. It has a seat height of 31.1 inches at its lowest setting and a dry weight totaling 416.7 lbs. The Fazer has and electric starter and a fuel capacity of 4.75 gallons.
    Yamaha Thundercat Engine and Transmission
    • The 1998 Thundercat is powered by a four-stroke, 16-valve, in-line, four-cylinder engine with a displacement of 36.55-cubic inches. It generates 100.00 horsepower at 11,500 rpm and 48.7 foot-pounds of torque at 9,500 rpm. The Thundercat has a six-speed transmission and a liquid cooling system.
    Yamaha Thundercat Brakes, Weight and Capacity
    • The Thundercat has dual-disc front brakes and single-disc rear brakes. It has a dry weight of 412.3 lbs. and a seat height of 31.3 inches at its lowest setting. The 1998 Thundercat has an electric starter, a 5.0-gallon fuel capacity and a top speed of 158.4 mph.
Jan 14, 2013 | 2003 Yamaha FZS 600 Fazer
Yamaha fazer fzs 03, keeps cutting out when i turn lights on or press brakes
Jan 14, 2013 | Yamaha Motorcycles
How much weight will I lose using an exercise bike?
Exercisebikes are a really good way of losing weight without having to show up at thegym! It depends on your weight etc but on average, 15 minutes of cycling withburn about 170 calories. But an effective routine should last around 45-60minutes.
Jul 30, 2012 | Exercise & Fitness
Kit ni hawa bhare plesure me . rear aur frount me
here is a chart for you ... depending upon total weight along with your , choose a pressure value.
weight 50kg 75kg 100kg
Road bike = 90psi 110psi 130psi
Mountain bike/hybrid
(hard surface use) = 65psi 80psi 95psi
Mountain bike
(off-road use) = 30psi 40psi 50psi
Mar 02, 2011 | Cycling
How well do Specialized Tricross bicycles compare to Touring bikes? The goal is trans-continental tour. Bikes I'm looking at are the Trek 520, Surly Long Haul Trucker, and comparable in price Specialized...
A comment regarding the Specialized. Wheel base is a little short. May or may not have heel clearance for your rear panniers. Gearing is not quite low enough for my taste. I would exchange the 12-27 cassette for at least an 11-32. You will be hauling at least 45 to 50 pounds of racks, panniers, and gear. Plus 28-30 pounds for the bike and your 170 pounds. Grand total of upwards of 250 pounds. Plus water. All being propelled by your legs, lungs, and heart.
As far as training, hit the weights. Can't emphasis enough the importance of strength when you are riding day after day. If you are carrying any extra weight, do your best to be as lean as possible. Any and all extra weight will conspire to sap strength from you and contribute to fatigue.
I rode from Seattle to San Francisco. 3 weeks covering 1000 miles supported. Bike was about 7 pounds too heavy and I was about 25 pounds too heavy despite losing weight prior to my trip. I was very fatigued by the end of the trip. Your trip will be twice as long carrying more gear. Are you using an Adventure Cycle mapped route?
Also something to consider. Use a lighter weight bicycle and carry your gear in a B.O.B. trailer. Trailer carries the bulk of the weight, so you can use a lighter bicycle. No need for a heavy front tire and rim.
Good Luck
Dec 21, 2010 | Cycling
What is the towing capacity of a 2004 Solara?
Not trying to sound like dodging the question but, If it's not written in your owners manual, your best bet is to call local toyota dealer & ask to be sure. Wouldn't want to guess on that & end up blowing your transmission or engine.
Feb 28, 2009 | 2004 Toyota Solara
Mongoose 2013 Crossway 150 Hybrid Bike With 10% Free Goods Medium Logo
380 people viewed this question
Top Mongoose Sport & Outdoor - Others Experts
Are you a Mongoose Sport and Outdoor - Other Expert? Answer questions, earn points and help others
