Question about Amcor Air Purifier with Double Ionizer and Washable Filter Air Purifier
I am looking for a replacement filter for my amcor treatment system 120 Part # RF-88
What is the best method for purifying water?
depends on where you are and when you want the water treated.
for camping and hiking , water purification tablets are quick and easy methods and one of the best ( used by the armed forces )
if you want it for home use
running the water through a ceramic filter then through an ultra-violet purifier will get rid of all the bugs
for larger volumes an osmosis purifying system as used by the water treatment works in council water supplies is best
so you need to specific as to when you want the water pure.
boiling water is ineffective as it concentrates the bugs and doesn;t kill them all, however distilling water by boiling off and collecting the steam back to water separates the bugs
Dec 26, 2016 | Air Purifiers
Socket melted with bulb in it
This was caused by heat retention and bad product design for the use you put it to. Unless you are comfortable working with the high voltage innards and acquiring and replacing the socket with something that you can get to work, this device is potentially a fire hazard now and should be replaced or otherwise repaired if possible.
Mar 28, 2014 | Honeywell UV100RM1 True UV Coil Treatment...
Need new filters
You may need to order the filters directly from Amcor unless you can find a local source
May 02, 2013 | Air Purifiers
I need a filter for Amcor Ficus Tree Air purifier
If the activated charcoal filter, take your old one apart and trim down a larger on from a competitve machine to fit yours. The same if it is a HEPA filter you want to change as well.
Otherwise metal and plastic filters can be washed. Spray with a grease cutter like 409, which will also lightly etch the metal without reacting with the plastic.
Jan 31, 2012 | Amcor Ficus Tree Air Purifier & Ionizer...
Where is the air filter on a saab 9000 turbo
Left hand side of the car under the left hand headlight. If you follow the air pipe from the turbo you should find a round drum like box with clips all around it
Oct 27, 2011 | Oreck 3M-OAC-RF Replacement Filters - For...
UV100E Ultraiolet system. Noticedbulb not coming
Honeywell has a great team of technical support personell, just call the number on your owners manual.
Jan 14, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
Air Purifiers Logo
Top Amcor Air Purifiers Experts
Are you an Amcor Air Purifier Expert? Answer questions, earn points and help others
