Question about Measuring Tools & Sensors
How to install the batteries in non contact voltage sensor 364 5015
The black piece on the back pushes straight out. Use the metal clip to push it out, batteries install in the black piece.
Posted on Mar 01, 2015
Does a GB 504 A have a battery?
The 504A uses two silver oxide 357 button batteries. The black top is just press fit in. Gently pry it off. The batteries install with the positive side down.
Aug 05, 2014 | Gb Electrical Gardner Bender GVD-504A...
Doesn't work Is there a battery?
All of these non-contact voltage testers require a battery. On this one, its located under the pocket clip assembly at the top. Consult the manual page 3 here: http://www.kleintools.com/sites/kleintools/files/instructions/NCVT-1-Non-Contact-Voltage-Tester-Instructions.pdf for instructions on how to install the two AAA batteries.
Dec 04, 2013 | Klein Tools Klein Ncvt-1 Non-Contact...
This is an old nikon camera FG. I have put a new battery into the camera and set to what the manual tells me to do. But looking through the viewfinder when I depress the shutter release button non of the...
Hi, see if the batteries or the battery are installed correctly (positive side as the bat. cover shows + sign).
Mesure the voltage = 3 volts.
Look at the battery cover and body contact, and see if there is contact battery leakage;clean if necessary.
Also the counter should be in 1, nothing happens, the counter SW dirty or defective contact.
Other Main PCB bad.
Best reggards
Feb 23, 2011 | Nikon Cameras
I need to know what batteries to put in my inductive voltage tester, Greenlee model 1010..
It takes two type 357 button cells. Fry's sells for $2, Radio Shack for about $3.
Make sure + sides goes into the body, not the cap.
Aug 12, 2010 | Greenlee GT-15 Non-Contact Low Voltage...
What kind of batteries do i need
2 "AA"batteries,but watch this model,theres a re call on it right now thru fluke
Mar 14, 2010 | Gb Electrical Gardner Bender GVD-504A...
Non-working Live Wire, model 505-A
Operates from 2-LR44 1.5 Volt batteries .
The back cover slides off.
Jul 27, 2009 | Acer Gardner Bender GVD-505A LIVE-WIRE...
I have 6 outlets that do not work.
I would start by determining if these 6 outlets are on the same circuit. Also I am usually not too confident in the non contact voltage tester you are using. They tend to give false positives if they contact anything or even if you move them fast. I would invest in an inexpensive multimeter whcih will allow you to test actual voltage across the poles and ground and also check for continuity between poles/ground (WITH CIRCUIT OFF ONLY).
Did these outlets previously work properly?
Jan 02, 2009 | Gb Electrical Gardner Bender GVD-504A...
Measuring Tools & Sensors Logo
731 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
