Question about Brother IntelliFAX Office Equipment & Supplies
Unclear fax we have a Brother Intelli FAX 980M. The faxes come thru to us very unclear. Remedy?
  • 186 Answers
SOURCE: Brother 1270E won't receive faxes
make sure the phone line is plugged into the port marked "line" not "phone"
Posted on Jun 21, 2007
Logjam
  • 159 Answers
SOURCE: how to use a brother fax- 645 plain paper fax
You may have been given a heap of junk. Happens all the time. Just place the document face down in the ADF and dial the number then press the green button to send.
Posted on Feb 28, 2008
Testimonial: "good and helpful"
  • 47 Answers
SOURCE: Brother Fax 4750 System error 76
try resetting the machine by pushing the features button, and then *2864 in quick succesion, if done correctly you will enter test mode, then enter 91, and then after that clears enter 99 to exit test mode. make a copy to see if it works, and if it doesn't it is time to replace the fixing assy.
Posted on May 12, 2008
leroyal
  • 2120 Answers
SOURCE: Cant receive faxes
Set your fax machine for AUTO RECEIVE. Unplug power cord and plug back in.
Posted on Sep 06, 2008
  • 4 Answers
SOURCE: BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Posted on Dec 02, 2008
INTELLI FAX MACHINE 775
Have you tried another regular phone on the same jack? There is a small LIU board in the fax that the phone line plugs into and it is possibly bad. Inexpensive board from Brother. Buy a whole unit from EBAY cheaply.
Jun 10, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother Inteifax 775 will not send fax
change the mode from TAD to F/T by pressing mode button on panel
Thanks
May 19, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Printing on line
try unplugging the machine then replug good luck
Jan 28, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Cant receive faxes
Sep 05, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother intelli fax 2800
It could be that your sending fax is sending paper not facing the scanner. In that case tell them to turn the paper over to send. Other than that, it could be that the telephone lines are so dirty that the fax protocl fails at the check frame signal. You will have to adjust the equalisation and line attenuation. Don't count on the telephone company to help you, they always want you to do everything 1st before they will admit to any fault on their part.
May 06, 2008 | Brother IntelliFAX 2800 Laser Fax
Memory full
If your brother Intelli Fax 775 says..Memory full, erase message...this is what you do. Press "menu 84" then press the fax start button. Your fax will print every fax in memory and it will clear itself. To turn off the memory so this does not happen again..Press Menu then 82, then a up or down button, so it reads "off". Then the stop/exit button, and your done.
Jan 28, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
26 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
