Question about Refrigerators
Need to remove small hairline scratch from white refrigerator door
Whirlpool white refrigerator
aborcass
  • 2651 Answers
SOURCE: Repainting doors on whirlpool white refrigerator
oowwwww!!! thats what we call in the refrig biz "refrig cancer" the door itself is actually rusting from the inside out. the older refrigs used fiberglass insulation inside the doors which has a tendency to hold moisture, and overthe years rusts through. the new door use blown-in poly styrene foam far less likey to hold moisture. That being said you could remove the door lightly sand and paint, can of krylon enamal aint should do it, at least for a little while anyway
Posted on Nov 30, 2008
codfish124
  • 36 Answers
SOURCE: scratch on stainless steel vertical doorright side
take off the top hing cover and remove it then lift up on the door
Posted on Dec 11, 2008
Greg20
  • 149 Answers
SOURCE: In side by side whirlpool refrigerator freezer ice cubes stick
if they are hollow and stuck together then u are not getting enough water..check the supply.
Posted on Jun 11, 2009
  • 1891 Answers
SOURCE: The kids put refrigerator magnets on the new
THERE IS A STAINLESS SCRATCH REMOVER SOLD BY MOST APPLIANCE STORES / ALSO HOME DEPOT . HAS HAD THIS PRODUCT .. MAKE SURE YOU GO WITH THE GRAIN . OR IT WILL GET WORSE ..MM
Posted on Jul 01, 2010
  • 14 Answers
SOURCE: How do I removes scratches
Not very easily.. if it is not coated with a lacquer or polyurethane clear coat, you can buff it like paint. If it has a 'texture' or appears to be brushed or matte, then you have to try to match the pattern, or change the entire door appearance..
steel wool is good to do the brushed look with.. I'd use 0000 (4 O or 4 ought) I'd contact the mfg if it is a matte finish or lacquered.
and no, SS is not very magnetic try a small magnet against it..probably wont work..
Posted on Dec 28, 2010
Scratch on door of stainless steel
If your question is how to get rid of it then what you need is a polishing compound and a wool polishing pad that goes on a drill. If it is a small scratch then you can get it with a dremel.
Feb 19, 2015 | Whirlpool Refrigerators
The kids put refrigerator magnets on the new Whirlpool Gold refrigerator freezer stainless steel doors. They left little scratches on the doors. Is there anyway of removing them?
Jul 01, 2010 | Refrigerators
Ice maker door does not close
maybe it has iced up
remove ice maker unit and check if there is ice build up there otherwise maybe door is deformed
you may need to replace
Nov 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My son used a magnet on the black door and made a several scratches
If the scratches aren't deep, you can try auto POLISH to remove them. NOT rubbing compound. If they are deep, you can hide them with car wax.
Nov 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do iremove the doors on my conquest
Remove the hinge cover at the top for both doors . Remove the bottom kick plate from the fridge . On the freezer door , follow the white tubing at the bottom about 6" to a connector . Remove the hose from the connector . Unplug the receptical at the top of the freezer door and remove the 3 screws from the top hinge . Lift the door upwards , pulling the bottom tube thru the bottom hinge . For refrig door , just remove the 3 screws holding the top hinge and lift door off bottom hinge . Hope this was helpful .
Aug 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Loose water dispenser lever on Whirlpool GD5RHAXNQ00 refrigerator
Something is likely broken in the dispenser.
This is how most dispensers are accessed.
Check for screws around or on the under side of the dispenser trim that can be removed to get the trim off. Sometimes the drip tray in the base of the dispenser needs to be removed to access the screws. Sometimes the top panel (touchpad) of the dispenser is removed to access the dispenser components.
If there are no screws, use a putty knife with the end wrapped with tape so the paint on the door panel is not scratched.
Start at the bottom of the trim and CAREFULLY pry the trim away from the door panel.
There may be small slots in the panel on the under side that the putty knife can be inserted into.
With the trim off, the dispenser components can be serviced.
Go here for Whirlpool Refrigerator Parts: http://www.repairclinic.com/Whirlpool-Refrigerator-Parts?z=100
www.RepairClinic.com
Feb 07, 2009 | Whirlpool GS6NBEXR Side by Side...
Nov 30, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
11 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
