Question about Samsung U660 Convoy 2 Used Cell Phone Verizon
Convoy 2 light stays on when off
Power is off led is on
How do i get my phone to send pic messages it just says invalid destination address every time i try to send a pic message?
This is from the following link: http://www.verizonwireless.com/support/knowledge-base-83298/To
Take and Send a Picture via Messaging.
  1. From the main screen, navigate: MENU > Media Center > Picture & Video.
    Utilize the 5-way navigation pad to highlight and the center button to select.
  2. Select My Pictures.
  3. Select a picture then press the right Soft key to choose Options.
  4. Select Send.
  5. Select Picture Message.
  6. Enter the 10-digit mobile phone number or email address then select OK.
  7. Select SEND.
To send an existing picture this is from the following link:
Send an Existing Picture via Messaging Samsung Convoy Convoy 2
Send an Existing Picture via Messaging - Samsung Convoy™/ Convoy™ 2
  3. Select the picture then press the right Soft key to select Options.
  4. Select Send.
  7. Select SEND.
Mar 03, 2016 | Samsung Convoy Cell Phone
I want to take off the ring silencer on convoy 3
I use Convoy 2. Go to "Setting" and select "Sounds settings".Select "Call Sounds" and select "Call ringtones". Then select "Call ringtones". Find "no ring" if you see it just select the ring tone you want and test the ring tone. I hope it is work for Convoy 3.
Sep 28, 2014 | Samsung Convoy Cell Phone
How to change language to english Samsung convoy 3
I have Convoy 2. To change the setting you press "menu" Usually center button on phone. Go to "Star" for settings. On Convoy 2 phone setting option 8, Press "OK"(center button), Select options 5 for language a press "OK" and select language. I hope Convoy 3 have the same menu.
Jun 17, 2014 | Samsung Convoy Cell Phone
Blinking heart beat led blinking
When the following situations, you need to replace the LCD screen:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/compaq-presario-cq40533tx-lcd-inverter-p-2632.html
May 24, 2013 | HEWLETT-PACKARD Hewlett Packard HP...
Blinking motherboard led
http://www.lcdinverter.info/hp-pavilion-dv6522em-lcd-inverter-p-4514.html
May 24, 2013 | Computers & Internet
Power led light on when pressing power it tuns on and goes of right away? power still lit..
I have the same problem, did you figure out what the problem is and solution by any chance? i purchased it recently, it started doing this the night after i left it on for the night. next day everytime i turn on, it turns off in 2 sec. after a month i tried a shot, it started and stayed up for 1 min may be... then same thing again 2 sec. i guess i have to wait for a year to turn it on .
garden led light
May 29, 2012 | Office Equipment & Supplies
My samsung convoy phone will power on, but it stops there. I get the Verizon wireless logo with the back light - than nothing.
I don't have a solution but I experienced the same problem tonight, which is why im here! any answers would be lovely, i've only had this phone for 2 weeks! :(
Mar 29, 2011 | Samsung Convoy Cell Phone
Can the front screen stay on? (Convoy)
No, the front screen cannot stay I. I checked this with a Samsung representative. The only thing you can do to get the front screen to light up without opening the phone up is press and hold the volume key while the phone is closed. This will light up the front screen for a few seconds.
Hope this helps!
May 11, 2010 | Samsung Convoy Cell Phone
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Samsung U660 Convoy 2 Used Cell Phone Verizon Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
