Question about Electrical Supplies
Gap for spark plug for honda electric start 7000 running watts 8750 starting watts
  • 2336 Answers
SOURCE: spark plug gap
Don't change the setting on the plug. The 400's are happiest when you just plug in new ones and ride. They like NGKs the best. There are two types for the 400. One runs hotter. This choice will depend on which country you live in and what the ambient temperatures are.
Posted on Nov 10, 2008
  • 2336 Answers
it is 0.036 in
  • 1779 Answers
SOURCE: 2004 Honda Accord spark plug gap
.044 Happy New Year!
Posted on Jan 02, 2009
joboo1
  • 257 Answers
SOURCE: cranks fast but wont start
Hi, You did a good job of diagnosing your problem. Gas in bowl and dry plugs, starts with fluid, But, to quote you, "won't go through carb" . If you feel confident, you should disassemble and clean the carb, as that is going to be the problem. As a tip, if the genset is going to sit make sure to turn off the fuel flow to the engine and run till the engine dies. They do not like to sit any length of time with fuel in the carb. Good Luck, this should Fixya!
Posted on Mar 02, 2009
CarlGehrke
  • 169 Answers
SOURCE: stops and starts
Most home standby generators are setup to run once a week so as to keep the engine lubed up and the generator windings dry. So if yours is comming on once a week at about the same time and running for something like 15 minutes, that's what is going on.
On the other hand, if your generator is starting and the switch is transferring somewhat randomly, you could have a problem with the neutral connection in your system, the power could really be going out and coming back on, and/or the control board in your generator could be broken.
Regards,
Carl
Posted on Mar 15, 2009
I have a predator 8750 watt generator that won't start. getting good spark at the plug. not getting fuel suspect the sylanoid at the bottom of the carb is inop. any ideas?
the solenoid will be an anti run on needle to shut off the fuel in the idle circuit or if up from the bottom shut off fuel into the main jet
test it with a multimeter to see if there is power to it
if so then replace the solenoid
Nov 30, 2017 | Electrical Supplies
Free manual 7000/8750 black max manual
Try Googling (Honda)(BM907000)(manual) without parens.
May 06, 2017 | Honda Black Max 7000 / 8750 Watt Portable...
My Powermate 8750 does not put out electricity! I checked the brushes seem ok? Tried flashing it at the brushes but not even a spark?
If the motor runs AND there is no electricity the power regulator modul can be damaged by faultering slide contacts or overload, if there is no circuit breaker protection is to find, a power assembly if there is used or a capacitor damaged.
Oct 06, 2016 | Powermate 8750 Watt Portable Generator...
I have a Predator 7000 - 8750 it will start on choke but start shaking and will not run off of choke or start off at you spark plug is dry but black what could be my problem
lack of fuel or blocked main jet
black is from excess fuel from choke but there is no fuel from the main jet to keep it running
Oct 09, 2015 | Motorcycles
Having trouble getting my BlackMax 7000 watt trifuel generator started on Propane.
Clean off the fuel connect points. Probably just not a clean line from sitting so long since last use.
Dec 25, 2014 | Honda Black Max 7000 / 8750 Watt Portable...
Why does the motor rpm fluctuate while running?
replace spring apparently it lost its tension for it to stay open you may also have a dirty carburetor if it does not run smoothly with the choke wide open have it serviced or clean it yourself if your mechanically inclined it should be a piece of cake.
Aug 21, 2014 | Honda Black Max 7000 / 8750 Watt Portable...
Steele 9000 watt generator won't start
Hi Derrick
I assume you can turn over the engine, and the engine has run previously?
Check for spark, -take off the plug lead and connect an old spark plug to the ignition lead open the gap up to about 5/16 inch . Tie the thread of the spark plug to the engine to hold it and earth it with a bit of soft wire. Wind over the engine you should get a nice fat blue spark. If you get a nice spark do you can eliminate ignition issues. This just leaves fuel. You can then focus on this.
Jacko
Apr 13, 2014 | Steele Products 9000 Watt Portable...
Electrical Supplies Logo
90 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
