Question about Kitchen Ranges
I need to find a glass cooktop replacement for my Kenmore Self-cleaning range model #C970-615128 (in Canada)... any ideas?
fridgetech
  • 473 Answers
SOURCE: Owners Manual
You can get the use and care guide at http://www3.sears.com/.  The part # is 318200838 and cost is $2.99.  Looks like there is a video available also for $35.56 and that part # is 316124202.  Would appreciate a solved rating for the advice.
Posted on Oct 17, 2007
SOURCE: Error code F3 on Kenmore 911.4658815 electric range
INGLIS Royal 100 STOVE F1 F2 F3 ERRORS
Mode lUP 48500 ( thats eye you, not ONE U )
I got the dreaded F3 error on the Display Panel,
every time I pressed BAKE or BROIL, BUT, I could
hear the three relays click in, and then kick out in
sequence, just before the F3 appeared.
I called Westinghouse ( that services INGLIS ) and
was told that F3 " means unpug for 1/2 hour and then
press CLEAR 5 Seconds to reset ". Which is nonsense.
All functions on the clock and timer work fine, and the
three relays were working, so its not a computer problem.
I called service REPAIR companies who said it was the
THERMOSTAT, and replace it - $147.99 ... The Glass tube
of the display is $200 with no circuit board, the relay board
is $300 and the computer/display is $400.
I did tests on the thermostat, first heating it with a propane
lighter, and it raised from 475 Ohms at room temperature,
to 600 ohms, so I knew it was functioning.
Then, I plugged in a variable resistor where the thermostat
plugs in. I went from Zero Ohms resistance to 5000 Ohms in
200 Ohms steps.
Zero Ohms ( equal to burnt out or unplugged) gives you
an immediate F1, which you cannot clear.
From 100 Ohms to 400 Ohms, you get Error F2, which
means thermostat too low.
From 400 Ohms to 665 Ohms there is no error.
At 665 Ohms, the BAKE will beep twice, stating that you
are setting the temperature at or lower than the actual temperature
of the oven ( you cant set the oven at 200, for example, if it is
already at 450 Degrees )
Using this 2 Beep code, I raised and lowered the resistance
and made a graph of the reading on the display versus the
OHMS that the thermostat would send to the controller:
665 Ohms = 170 Degrees Farenheit, which is the
lowest reading in the BAKE MODE.
800 Ohms = 240 Degrees
1100 Ohms = 380 Degrees
1400 Ohms = 500 Degrees, which iis the maximum that
the unit showed in the BAKE MODE.
1430 Ohms to 2750 Ohms, there was no reading, an NO ERRORS.
ABOVE 2750 OHMS, the F1 ERROR appeared again, meaning
thermostat out of range.
Note that the computer module supplies 5 volts DC to the thermostat,
to see the changes in current with changing resistance.
You can easily check the thermostat to see if it is OK, with an
Ohmeter across the thermostat, which should read about 475 Ohms
at room temperature. If it reads Zero, it is burnt out. If it reads
over 2750, it is defective. Check to see if the thermistor in the
tube is SHORTED to the steel outter case as well, as this should be
infinite ohms ( no contact )- if it reads ZERO it is shorted to case.
I found that on the Internet, there are hundreds of people looking for
the F3 code for the ROYAL 100 ( model number IUP 48500 )
and a general search shows that for 400 " other" models of all kinds,
F3 = REPLACE THERMOSTAT ! Not on this model, and all typical searches
for technical support or diagrams or troubleshooting did not even list
the Royal 100 AT ALL, as if it never existed.
I then did tests on the relay board, and replaced the capacitors, a few diodes,
some resistors that were a bit out of value, and two transistors that were
a bit out of value. There was no change in F3.
I cleaned the contacts on the three relays using a typical board fingernail
file that ladies use for their finger nails ( I keep a supply for cleaning
relay contacts, since there is sandpaper on both sides, and they are
tiny enough to fit between most contacts ). THEN, I realized that the BROIL
contacts were bouncing apart - they were too far apart, and not closing
properly, so I bent the stationary contact a bit closer, and plugged in the
stove = NO ERRORS..
I analysed the circuit, and after turning on the 3 relays ( NOTE, when you
turn on BAKE, as in a regular oven, THE BROIL ELEMENT goes on at first
to quickly help the BAKE element get the oven up to temperature )
there is a feedback circuit that feeds 250 Volts back into the 5 Volt computer
chip ( ! ! ! ) It uses two 22 Meg Ohm resistors in series for a total of 44 Million
Ohms, which shows about 46 volts accross the resistors. Since the gas
tube display uses 30 volts to light up, the 46 volts is within the computer
board's ability to lower it enough to feed into the computer. There are transisors
on the back of the control board and Zener diodes etc. to " compare " the
voltage, where 46 volts in = 250, and Zero volts, means that the element
is burnt out, the element fuse in the fuse panel is burnt out, or, the relay
contacts are dirty. The relays are absolutely standard 24 volt relays,
with a plasic cover that snaps off if you pull and wiggle it. You will see
the round silver contact pads are blackened and probaly pitted.
Sand these flat until silver/brass shiny, and test to make certain that
when you press the metal lever that the magnetic coil pulls DOWN,
that the contacts touch! If they do not touch tight, bend the
stationary contact in a tiny bit and test again.
You can first check the fuses - there are two 120 volt fuses in the
fuse panel that give you 250. Then, you can unplug the stove,
and use an OHM meter to see if the element is burnt. The two types
of elements I checked were 3000 Watt at 18.7 Ohms, and 2500 Watt,
at 48 Ohms. If the elements are burnt out, you will get ZERO ohms.
If the element is burnt internally through the insulation in the tube,
and shorting to ground, between the ends and the steel back of the
stove ( ground) you will get a reading of X amount of ohms ( which
normally should be ZERO ) If the element is burnt or shorted to
ground, replace.
The F3 error is a really dumb mechanical errror of whether the 250 volts
is on the elements. It does not involve the computer or the thermostat,
or the relay " electronics" at all - it is just simply 3 contacts that supply
250 Volts, and whether or not the contacts work, the elements work,
or the fuses work. This the same 250 Volts that is on an ordinary
dial stove, and the dumbest part of the whole unit.
When I called service, they said they would order the $147.95 temperature
thermostat, and " see if this fixes the problem", if not they would start
replacing the modules - $300 and $400, plus labour, plus tax etc., and
since the problem was on the module, this would cost $147.95 + $300,
plus $75.00 for the first 15 minutes, and $15 for each additional 15 minutes,
for a total of about $466 dollars ( CDN ) which is about $460 dollars US.
A package of 25 fingernail files is $1.00 at the dollar store. That is all that
it cost to fix the problem. You need a square ( Robertson ) head screwdriver
to remove the 7 screws on the back panel, and then you wiggle the
covers off the relays, and clean them. It takes 10 minutes.
good luck ! Damned the manufacturers for not putting this information
in the user manual.
Robin Graves, January 2008, kidbots.com
Posted on Feb 01, 2008
Agent Matt
  • 8 Answers
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Posted on Apr 07, 2008
SOURCE: how to use the self cleaning feature of kenmore gas range
I NEED THE BOOK ON HOW TO USE THE OVEN ON THE STOVE RANGE
Posted on Nov 27, 2008
SOURCE: Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Posted on Mar 26, 2010
Looking for instructions on how to replace the main cooktop on our kenmore elite elecric range, model 790
To raise and lower the cooktop:
1. Remove all items from cooktop and set aside.
2. Grasp the sides of the cooktop and then lift from the
3. Lift the cookop high enough to allow the support rods
to snap into place. The llft-up rods will support the
cooktop in the raised position.
4. If necessary, clean underneath using hot, soapy water
and a clean cloth; then dry.
5. To lower the cooktop, grasp the front corner of each
side of the top while pushing back on each rod with
the heel of your hand. This will release the notched
support. Hold the range cooktop and gently slide the
top back down level to the range.
Aug 03, 2016 | Kenmore Kitchen Ranges
Element in oven gets red hot, burns food being baked, will not shut off unless I unplug oven. how to fix?
You need a new thermostat or oven sensor. These people are pretty good but I am have trouble find details on the model number you gave. This gives an idea.
http://www.appliancepartspros.com/kenmore-range-cooktop-oven-fuse-sensor.html
Another place here
http://www.partselect.ca/Model-Number-Locator+8+repair.htm
Nov 15, 2015 | Kenmore Kitchen Ranges
Replace cooktop
Igniter? Is this a gas range (cooktop) or electric? How about providing a model number; or a picture of your cooktop and the igniters you want to disconnect?
Sep 18, 2014 | Kenmore Kitchen Ranges
Kenmore 629
Could be the lock needs replacing the oven won't self clean if the door lock isn't functioning it's a safety thing so you don't get your face burnt .
Ray
Apr 16, 2014 | Kenmore Cooktops
Managemylife com
From the manual:
To turn the Cooktop Lockout Feature OFF:
1. Press and hold (_ until "CLO" appears (Figure 3). Continue holding
until a second beep sounds (after 3 seconds). I_1will disappear from
the display indicating the cooktop may be used normally (Figure 4).
Note: Starting a Self-Clean cycle will automatically turn ON the Cooktop
Lockout feature. The cooktop will remain locked until the Self-Clean cycle
has completed and the oven door has unlocked. If a power failure occurs
after the Cooktop Lockout has been activated, you must turn OFF the
Cooktop Lockout feature before being able to use the cooktop features
again.
Dec 14, 2013 | Stoves Kitchen Ranges
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
After self- cleaning my Kenmore Gas Range, I have not been able to get the 'Cooktop Lock' light turned off! So while I can use my oven for baking I can't turn the gas on the top of my stove! I have...
This may be a silly question but, did you just try turning off the circuit breaker for a couple minutes to see if it resets itself when you flip it back on?
Nov 21, 2010 | Kenmore Kitchen Ranges
Glass cooktop scratched
Unfortunately, these style cooktops are VERY fragile to scratching and cracking. The wrong kind of cookware can also mark them. Copper or aluminum pots and pans can discolor them. Do not use pyrex (glass) cookware on them either. Stainless is the best. NO CAST IRON either. Anyways, there's not much can be done without replacing the top itself.
Apr 09, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
I don't know where to look for a Glass Cooktop Replacement
What is your model number and I can look up the part and tell you what they cost so you can call some appliance stores for comparison
Jan 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
