Question about IBM NetVista PC Desktop
Can't Boot from "CD"?
I can not enter "BIOS", I'm left with a black screen with only one option to to press F1. I used zero writing software to completley wipe the drive to do a clean install of xp home, but the computer will not boot from "CD" and go into setup? the computer is an IBM NetVista 2257 82U with a 40GB hard drive & 512MB ram. What do I have to do to get it to boot from "CD"?
  • jkonkle Jun 20, 2009
    There is no info on the MB, the sticker on the bottom indicates that it is a IBM, NetVista, machine type 2257, model 82U, Manufacture date 203?
  • jkonkle Jun 21, 2009
    Thank-you for the link, I found the manual, it is alot more complicated compared to the other computers I have worked on. Holding the F1 key did get me into BIOS, I came accross the 2 IBM CD's that did come with the computer, but honestly, I'm confused, it shouldn't have to be this hard, there is absolutly nothing in the bios settings for configuring the boot order, bios does recognize the cd rom but it still will not boot from cd & I know that the cd drive does work. Each time I turn the computer on it goes through the memory test at the IBM screen & then it switches to a black & white DOS screen with what looks like a drawing of a floppy disk with arrows pointing to the floppy drive, but when I press F1 the computer repeats the same cycle. I even disabled the floppy in bios hoping that, that would force the motherboard to boot from cd rom, but still, nothing. No matter what I try or do, the computer will not boot the cd rom for Windows XP home setup & I have 3 copies of XP home CD?
  • 40 Answers
Need to know what computer and model #
Posted on Jun 20, 2009
  • 1 more comment
  • Rob Carpenter Jun 20, 2009
    You indicate you are left with the press f1 option. Have you pressed the f1 key on your keyboard?
    Do you have the manual to this IBM? If not you can get one at
    http://www-01.ibm.com/support/search.wss...
    You should be able to get a copy at this sight. It should help you with this. Make sure everything is connected properly and nothing is left loose. pressing the f1 key should get you into the bios. Once there you should be able to check the bootable device list and make sure your cd rom is enabled to be bootable. If you enable it you need to save your changes and restart with cd in and it should boot to your disk providing the disk is a bootable disk.Let me know haw this works for you.
  • Rob Carpenter Jun 21, 2009
    O.K. does the computer have a floppy drive in it? If so you can insert a 98 bootup disk in it and restart your computer. once bootup is installed you can tell your computer to setup with the xp cd. Try this, it is not that hard. I have done this on older computers. Some computers does not give you the option to boot from a cd.Give this a try and let me know how it works.
How do i get my HP pavilion 521n to boot DVD ?
  • Press the "F1" or "F10" key when the logo appears on the screen to enter the BIOS setup.
  • Navigate to the BIOS menu "Advanced" using the right/left arrow keys on your keyboard.
  • Get to the option "Boot Order" with up/down arrow keys, and press "Enter."
  • Select the first boot device under the "Boot Order menu option and press "Enter."
  • Select "DVD" from the list of available boot devices and press "Enter."
  • Press the "F10" key to save your changes and exit the BIOS setup. The computer will automatically restart and then will boot from the DVD.
  • Aug 05, 2013 | Computers & Internet
    Diskette 0 seek startup failure
    restart your system and press delete to enter the bios mode and change the boot options set 1st boot device as cd/DVD rom and 2nd boot device as HDD if you are not using floppy drive just disable it. After finishing the changes press f10 to save the changes and exit
    Feb 24, 2012 | Microsoft Windows Vista Home Premium with...
    My acer aspire one kav60 fell and gives the options to start using safe mode,,safe mode with networking,,last known settings that workedq,, ect but restarts once it gets to the windows xp splash screen...
    Try to restart the system using " last known good configuration " option.
    If the problem persist you may have to restore the system to earlier restore point by starting the system in safe mode.
    hope this will help.
    With regards:
    Kartikey.
    Apr 14, 2011 | Acer Aspire One PC Notebook
    How to reset to factory settings a toshiba satellite A305-S6829 with Vista ? (pressing 0, or F8 didn't bring me far!
    To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
    Note that this erases all data, and reloads all factory default software. Be sure to back up all your important personal data beforehand!
    Dec 31, 2010 | Toshiba Computers & Internet
    Iam at black screen that said F1 to resume i pressed and sendme to bios utility how can i go back to regular screen windows
    What was the error-message just BEFORE that 'F1' message?
    Turn the computer off, wait, and turn the computer on.
    If you get into BIOS SETUP,
    use the "arrow" keys (UP, DOWN, LEFT, RIGHT)
    to highlight the 'Load BIOS defaults' menu-item.
    Press ENTER to apply that option.
    Use the arrow keys to select "Save and Exit from BIOS setup".
    Press ENTER to apply.
    Oct 24, 2010 | Computers & Internet
    Cannot boot from cd and run setup
    When booting, the writing on the black screen should give you a couple of options akin to
    Press F2 to edit boot options or
    Press "Del" to enter setup. (bios)
    You can use either, but you need to set your CD/DVD disk drive as the first boot option.
    May 04, 2010 | Microsoft Windows XP Professional SP2
    I have a Compac D300A Desktop you said for me to
    If you want to boot your computer with disk you need to set first boot device as your cd or dvd rom.
    For that when you power up the computer press F1 or F2 or "del" then you can enter in bios.
    Then go to boot option then set first boot device as your cd ro dvd rom .then save settings and exit.
    Then put disk in rom then it boot with that disk.
    Let me know if you need more assistanse.
    Thanks.
    Sep 20, 2009 | Compaq Computers & Internet
    Need to get into bios
    Dear friend for go BIOS some computers Need to preess DEL, Some Computer need to Press F1, Some Computer need to pree F2. you didnt write about your computer... One solution i have ... Press DELL+F1+F2 At starting your sustem... Here is two option to find out Boot Sequence from BIOS.... some BIOS Have Independent Boot Menu.. IN Boot menu you may see boot sequence... there you have change it. For Other Option You may go the Advanced BIOS Setting Option There you may find First boot device, Second Boot device..... Or Boot sequence.... find out your solution...
    For Master And slave..setting in CD/DVD rom ..
    set jumper.. near ide or sata cable... for setting as Master...
    Set jumper After Master jumper... for setting as slave..
    Best Regards.. sumon
    Mar 27, 2009 | Computers & Internet
    Changing BIOS priority on toshiba satelite 5005-s504
    as i recall, ntloader is software for the OS load, after hardware boot, so you already passed up your chance to enter bios, which you realize. i used to have a toshiba laptop, was it the delete key or F2 to enter BIOS? try delete, and make sure youre pressing it from restart like once a second as it's booting to make sure you hit it in the windows of time it's looking for key presses before it's time to load the operating system. you'll be fine. it's just unnerving to be locked out like that...
    Feb 01, 2009 | Toshiba Satellite 5005-S504 Notebook
    Reformatting my computer
    • Using System Recovery CDs
    • Change the boot order in the BIOS:-
    • Turn off the computer:
    • Disconnect devices that are connected to USB, Fire wire, parallel and serial ports, except the keyboard, the mouse anb Internet Connection.
    • Turn on the computer.
    • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.)
    • Wait until the BIOS setup program opens.
    • Press the right arrow key to select Boot.
    • Press the down arrow key to select Boot Device Priority, and then press Enter on the keyboard.
    • Change the first boot device to CD-ROM using one of these methods:
    • Press the down arrow key to select the CD-ROM item. Press the + (plus) key to move the CD-ROM item up until it is the first item in the list.
    • Press the down arrow key to highlight the First Boot Device selection. Press the + (plus) key until CD-ROM is the selection.
    • Start the recovery:-
    • Press the Eject button on the top CD-ROM drive, and wait for the tray to open. Insert the System Recovery CD #1 and close the tray.
    • Press the F10 key to save the changes and exit BIOS.
    • With Yes selected, press Enter.
    • The recovery window automatically starts; wait for the onscreen instructions to display, and then follow the instructions:-
    • Press R, and then press the F key again.
    • Click yes to perform the full system recovery.
    • Insert the remaining CDs when directed.
    • When the recovery program finishes, click Restart to restart the computer.
    • Before the computer restarts, the CD tray ejects. Remove the CD
    • Return the BIOS to the previous setting
    • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.) Wait until the BIOS setup program opens.
    • Press F5 Key to Set Default Settings in BIOS.
    • Select yes and press Enter.
    • Complete the recovery
    • After the computer restarts, a series of startup screens appear. Complete Microsoft Windows setup as follows:
    • Complete the registration process, and then reconnect the devices that were disconnected earlier.
    • Reinstall software that did not originally come with the computer.
    • Write data files that were previously saved on the backup CD or diskette you made from the hard disk.
    Jul 04, 2008 | Computers & Internet
    IBM NetVista PC Desktop Logo
    389 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    pankaj rautela
    pankaj rautela
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
