Question about Keurig Platinum B70 Coffee Maker
The water in my keurig starts to flow when i turn the machine on
4 Suggested Answers
tgmusicgirl
  • 92 Answers
SOURCE: This morning my keurig pumping the water onto the
Yep... you goto take the metal bottom off and see if the small ty-rap broke off the translucent hose... you can replace it with a Panduit 4" ty-rap... the ones that Keurig uses are smaller and can use to be beefed up... there are 2 hoses coming off the motor... one from the watter fill tank and the other going to the main water tank... Could be anywhere in that path...
Posted on May 17, 2010
  • 40 Answers
SOURCE: MY KEURIG IS BLOCKED AND THE WATER WILL NOT COME OUT
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage.
Posted on Oct 07, 2010
  • 40 Answers
SOURCE: Keurig Platinum is clogged
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Posted on Nov 21, 2010
Wont start brewing and display wont turn off just says brewing
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 22, 2011 | Keurig B60 Coffee Maker
The machine don't give cup of coffee. ACL screen turn off with the message "not ready". The 3 selection's cup buttons are off. It seems that water does not heat.
heatman101';
Sep 09, 2011 | Keurig B50 Coffee Maker
When i turn it on it says not ready. you hear the pump come on and the water starts comeing out. it wont stop until you turn it off
heatman101
Sep 05, 2011 | Keurig B70 Coffee Maker
Water light blinks...brew flashes...then it turns off?????
heatman101
Aug 20, 2011 | Keurig B30 Mini Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
13 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
