Question about Dell Latitude E5500 Laptop
Flash rom test fail WCD41-OQW - Dell Latitude E5500 Laptop
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
I think you need to replace that drive. If your system is under warranty, call Dell for a replacement.
Posted on Apr 29, 2014
You can try the hdd version or USB version to flash your current ROM. Please read the review first before you flash your ROM with a certain version of ROM.
Apr 23, 2014 | Dell Latitude E5500 Laptop
Firmware failed
Are you installing a rom from .zip file?
I assume you are doing that.
To follow these steps, you will need ClockWorkMode and rooted stock rom. In recovery mode, load CWM, Clear dalvik cache and data partion and then install ROM .zip fike. Try to obtain new package of ROM files. The one you may have may have some internal configuration problems.
Now, if your phone doesn't load any OS, try flashing with ODIN with stock ROM packages. You can download it from xda-developers or by searchibg it in google.. Note, try to watch some demos from youtube before actually doing it. It will help you to know correct procedures.
Nov 27, 2012 | Huawei Sonic Plus U8661 Dual Sim 2 Line...
Flashing problem can you help me.. I follow your procedure.. but at the end it says The flashing failed. Do you want to retry the flashing? HRESULT 0x8401f141 (-2080247487) Flash: Boot rom was not d
press retry then remove the battery and usb then put back the battery, connect usb and immediately press ok while its trying to detect usb port....
Mar 17, 2012 | Nokia 2690 Cell Phone
Error code 00F0:136C IDE FAILED BLANK MEDIA OR NO MEDIA IS PRESENT IN OPTICAL DRIVE. IS THE HDD FRIED OR WHAT?
You probably ran the 32-bit diagnostics in this Dell computer.
The error code 00F0:136C, actually is talking about the "OPTICAL DRIVE,"which is your CD/DVD ROM; not the hard drive.
That will fail since, I am assuming you didn't put anything inside the CD-ROM.
The diagnostics tests everything and in this case, it tested the CD-ROM and failed since there is no CD inside the CD/DVD-ROM.
Hope this helps.
Thanks,
Oliver
Jul 28, 2011 | Dell Inspiron 6000 Notebook
Flash test Fail! wChipID = 0x80 - Disimage Info length = 3600000 checksum = 4d8323a7 -starting counting ...................... ................... checksum = 4ad32f1b Test Fail! Press any...
- Disimage Info
length = 3600000
checksum = 4d8323a7
-starting counting
checksum = 4ad32f1b
Test Fail!
Press any key to continue...
Do not work FM,TV,Camera after using wrong rom
Help please with gsmart i120
Merlinwarwar@gmail.com
Feb 16, 2010 | Gigabyte g-Smart Smartphone
CD-ROM Drive has a driver problem (Dell XPS M1530)
Driver will be on Opperating System it is a Sony Product that is extemely common.
If the Hardware has failed... it can also give you that same error... bit misleading. I'm assuming the light in the front of the CD Rom is flashing when you push the eject button and of course the door opens. This all can be true and the CD Rom could still be bad.
Try to locate a replacement CD Rom to test... friend or the cost of a new one is about 45-50 dollars...
:D
Jan 03, 2010 | Dell XPS M1530 Laptop
Gigabyte G-Smart-i 128 Cellphone ROM upgrade problem
i have same problem on my gsmart i.. work`s with original rom on i128?? gsmart i fails after format utility use two block`s.. any sugestions?
Jun 07, 2009 | Gigabyte g-Smart Smartphone
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Cd rom has stopped working. the light is flashing as if it is working but the cd is not spinning.
Check the disk for scratches, and try other disks to make sure the problem is not unique to that one disk. If all disks fail, then double-click on My Computer, then double click on the CD-Rom drive and see if a CD will run. The "autorun" option may have been disabled, which is very noticeable if you've been used to this feature working. To re-enable autorun, right click on the cd-rom drive in My Computer, and go to device properties - recheck the autorun or autoplay option.
If none of the above resolve, then turn off your computer. Open up your computer with screwdriver. Unplug and replug the cd-rom driver. Restart computer. Test cd-rom drive again.
If it still fails, Make sure you are connected to the internet (I am assuming Windows XP - Vista may vary): Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> DVD/CD Rom Drives - se if the drive has a yellow exclamation by it - if it does, then right click on the yellow exclamation, and click install drivers - windows will most likely find a solution
If all of the above fails, write back with more details, including model/manufatcurer of cd-rom drive, and model/manufatcurer of computer.
Jun 11, 2008 | Computers & Internet
Dell Latitude E5500 Laptop Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
