Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Cutter engage lever does not work
Bolens 760-770
Tractor will not start with key. It will start jumping selenoid. Where is the starter safety switch?
check the safety swich on the foot pedal and the cutter engagement if its a manual engagement lever
Mar 30, 2016 | Garden
Toro zero turn mower wont move
there is a parking brake turn it off if that still dont work check your hydrolic lines
Jan 21, 2014 | Garden
Bolens 13am762f765
CHECK ALL BELTS FOR STRETCHED SIGNS AND WEAR. MAKE SURE A BELT IS NOT SLIPPING AFTER HEATING UP. ALSO CHECK ANY MECHANICAL SHIFT RODS OR LINKAGE
Dec 19, 2013 | Garden
I need a spare part for a Bolens LTX 14 Hydro grass cutter
Here's a link to find parts for your Bolens mower.
Mar 11, 2013 | Cars & Trucks
Bolens riding lawnmower st100 pto won't engage?
check for power to the clutch if yes the clutch could be bad or a wire going to it if no power check the safety switches
May 17, 2012 | Briggs & Stratton Garden
Bolens clutch wont engage
check to see if there is something caught around the blades that won't allow to turn
Jun 24, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have an atco commadore B20 that cuts out when I
it could be tight cutter bearings in the deck next time it cuts out switch off the motor and try to turn the deck by hand if its realy tight its seizing up on you
May 02, 2010 | Garden
We the multi-functional mixer attachments but now unable to get shredder to attach correctly
Remove the shaft an cutter first and install the outside case of the shredder. Tighten thumb screw. You may have to lift up on a lever that runs in a groove in the shaft to remove the shaft.
Next install the shaft with cutter attached. Lube the shaft with tiny bit of mineral oil or food safe grease. Lift the lever mentioned above and rotate till the shaft seats and then drop the lever and make sure it is engaged.
Feb 03, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
15 people viewed this question
Top Parks Optical Garden Experts
Roland W VanLue
Roland W VanLue
Renee Knafel-Bullock
Mike Squire
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
