Question about Watches
Winder stiff to turn - Watches
How do I set my Invitation 11286 chronograph?
Just gently pull the winder knob fully outwards and you should feel one or more clicks. Each of these clicks is associated with a different function. So, select one of these click positions and turn the winder clockwise and see what happens. Then turn it anticlockwise and see what it does. Then repeat for each of the click positions.
I've also looked online but had no luck.
Jul 16, 2015 | Watches
Steinhausen tm-478 single watch winder how it worcks
Watch Winder Setting & Instructions for Executive Collection
Jared Tracy
posted this on March 30, 2012, 2:44 PM
  • inShare
  • There are four modes for our Executive Collection of Watch Winders (TM and SM series):
    Mode 1 (both switches with the O pressed in): rotates for 180 seconds on then 12 minutes off.
    Mode 2 (first switch with the O pressed in, second switch with the I pressed in): rotates 180 second on then 15 minutes off.
    Mode 3 (first switch with the I pressed in, second switch with the O pressed in): rotates 180 seconds on then 18 minutes off, then 180 seconds in the opposite direction.
    Mode 4 (both switches with the I pressed in): rotates 180 seconds on then 24 minutes off.
    For switching winding direction:
    I pressed in will wind clockwise
    II pressed in will wind counter clockwise
    Neither pressed in will turn the winder off
    *Please note that the CW and CCW settings do not apply when the winder is set to Mode 3 as this mode winds in both directions.
Apr 10, 2014 | Steinhausen TM-478 New Single Watch Winder...
How do i set the date on my oyster perpechual movement watch
Unscrew crown pullout 2 stepsturn hands around till the date changes .this will indicate to you it is midnight .turn ands around to right time.if you are setting this in the afternoon remember to go past the 12.When this is done push winder in 1 step and turn winder clockwise or anti cclocwise and this will let you set day or date. When you finish push winder back in and lock down.
Jul 10, 2010 | Rolex Day-Date President 118238 Wristwatch
How to set the date?
Pull the watchs winder to the first detent then turn either clockwise or counter clock wise. Then stop the day before the date you want it set, pull it all the way out to its last detent and manually turn the hands with the winder until it changes (around 3 or 4pm usually) so you know it's the AM and set your watch for the correct time.
May 01, 2010 | Giorgio Armani Emporio Armani watches...
Watch not running
The watch should start when the winder is returned home position.
If pressing the winder does not cause the watch to start it could be that the winder may need to be screwed in (some watches include this as an additional feature to improve water resistance). Turn the winder to the right.
The wacth should now start. if it still does not start, I suggest you find your nearest dealer in your area and speak to them about it.
( You can find your nearest dealer at http://www.tagheuer.com/tools/sitemap/index.lbl?lang=en ).
Apr 08, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I have just purchased a guess w12575 ladies watch but am unable to alter the time on it as the winder won't open. i had no instructions in the box when it arrived to help me. I have tried pulling the...
Some winders need to be unscrewed (its a water resistance feature).
Try turning the winder anticlockwise about a quarter of a turn or so.
(Don't forget to screw it back in when you have finished!)
Mar 23, 2010 | Guess Sport Leather Strap W12575L1 WW...
How do I ajust the time in a watch 100 years old,
I would expect that pulling out the winder and turning it will move the hands.
If it will not pull out, it could be that the winder screws in for security. Try turning the winder anticlockwise and the pulling it out.
Jan 17, 2010 | Watches
Instructions were for a different fully analog model. The major problem aside from the digital settings, is the mechanical setting of the hands. Even after pulling crown out to position 3, the hands won't...
Tag Multigraph: With the crown pushed in you turn the winder quickly a couple of times and the digital displays appear. Scroll through to the function you want then pull the crown out and turn it to change time/settings. The time can be changed either by pulling the crown out on the T setting (digital) or when no digital display is shown on the dial. If you turn the winder slowly the time/settings change very slowly, which is barely visible. If you flick the winder round very quickly the settings leap forward faster.
Aug 05, 2009 | Tag Heuer 2000 Classic Multigraph...
I have a Rado DiaStar watch (with digital display), and the hands are out of synch with the digital display. Is there a way of adjusting the hands independently of the display? or must it be sent back to...
Hears how i do my watch, i have the same watch as you.Just make sure nothing is displayed on the clock face by turning the winder, ie NO digital time, NO daul time, NO alarm, NO stop watch etc, Pull out the winder(crown) and adjust the hands to the time you require by spinning the winder.(Gentley for mins and fast for hours) The digital clock will display wilst doing this, but not change the time.handy if you want to sync both clocks.Push the winder back in at the time to sync and the digital display will go out, then spin the winder again if you want to display the digital features. I hope this helps, please post if it does, Maurice Chevalier- Herts
Nov 01, 2008 | Rado Diastar Anatom Jubile watch
Adjust the date and day on a festina 3 dial watch
I've just worked it out! Change month....depress inset button on side above hand winder. One push with cocktail stick or similar will advance month. Change date.....pull out hand winder half way, turn knob anti-clockwise until desired number is met. Change day...... pull out hand winder fully, turn clockwise passing midnight repeatedly until day is set, continue to set time, keeping an eye on 24 hour display for am/pm.
All the best, Bob
May 06, 2008 | La Crosse Technology E. Howard Ambassador...
Watches Logo
11 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
