Question about Keurig Platinum B70 Coffee Maker
My keurig starts the water flowing as soon as i turn it on and doesnt quit until it runs out of water
5 Suggested Answers
  • 11 Answers
SOURCE: water in Keurig single cup
Make sure there is water before you do all this. Unplug it from power wait 1 minute plug it back in. Open and close the coffee holder, wait a few seconds, press any of the brewers. Basically reset the whole system.
Posted on Dec 07, 2008
  • 40 Answers
SOURCE: MY KEURIG IS BLOCKED AND THE WATER WILL NOT COME OUT
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage.
Posted on Oct 07, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: I'm having a flow problem with my keurig brewer.
you will need to give it a vinegar flush..white vinegar..I put about 1/2 cup with a full tank of water..keep running the water until empty..then run thru a full load of clean water..then taste some of the hot water..to see if the taste is gone....
you do not need to use k-cups for this
Posted on Dec 18, 2010
heatman101
  • 43501 Answers
SOURCE: My Keurig B60...the water runs
Here is a tip that I wrote about how to register your Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
Keurig Registration, User Manuals, Cleaning, and Troubleshooting
heatman101
Posted on Mar 01, 2011
Starts running water when I turn it on, and won't stop
Did you do the unplug, take off reservoir turn upside down and shake a little? It has worked for others.
Here is video of troubleshooting with added upside down theory. Fix Your Broken Keurig Coffee Maker New tips and tricks Water Flow Issues
Nov 28, 2015 | Keurig Vue Brewer V500 Single Cup Home...
How can I fix my Keurig Coffee maker? It pumps water from the time it is turned on 'till it indicates add water. Any suggestions?
either the heating element has failed or a thermal overheat trip device or thermal fuse has failed
you need to use a meter and see if the heating element is getting AC power
perhaps the pump actuator usualy a relay or a triac device has failed and gone short or fused contacts ....
hard one to diag from words only
Dec 04, 2014 | Keurig Coffee Makers & Espresso Machines
Keurig not brewing
Our unit (the mini) would only blink red but would not brew. It didn't make any noise and seemed like it was dead. To fix this, leave the unit plugged in but powered off. If you haven't already done so, add water to the top of the unit and then open the pod holder so that the water flows into the internal storage tank. Hold the brew button in (don't let go until it is done brewing) and the light will turn on - after a while it will start brewing. Let go of the button once it has finished brewing. According to a Keurig rep - this problem is often caused by using cold water straight from the fridge.
Sep 17, 2013 | Keurig Coffee Makers & Espresso Machines
When i turn it on it says not ready. you hear the pump come on and the water starts comeing out. it wont stop until you turn it off
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 05, 2011 | Keurig B70 Coffee Maker
How do I descale my Keyrig B 60
The first thing that you will need to do the descaling is up to 48 ounces of white vinegar. The vinegar will be run through your machine to dissolve the mineral build up in the machine that is left behind by the water in the heating process.When the water is heated some of the mineral content in the water is turned into a hard rock like material. This adheres to the sides of the tubing and will eventually close off the flow of the water through the tubing. Running the vinegar through the tubing will dissolve the mineral and clean up the tubing in the machine.
Next, place the vinegar into the water container. Make sure that the "Auto Off" feature is turned off.During this cleaning process do not have any K-cups in the machine.Then using a ceramic mug to catch the liquid, press the brew cycle and then discard the liquid that comes out into your sink. Do this until the "add water" comes on. Then let the unit stand for at least four hours. Do not turn the unit off during this time.
After the four hour plus time period,discard any vinegar left in the water tank and fill the tank with fresh water. Now repeat the process of running the brew cycle into the mug and discarding the liquid until you get the "add water"message again. By this time you should have all of the residual vinegar purged from the system, but if you still notice any residual taste then run more water through the unit until it is clear.
This should clean the machine and takeaway the "DE-SCALE" message. If you still have the message after the cleaning then you may have to repeat the process again.
Also at this time it is a good ides to clean the pins that pierce the K-cup. To do this take a small paperclip and bend the end of it out so that you have about a 1" prong sticking out. Push the paper clip into the hole of the top and bottom pins. This will also clean out any material that maybe stuck inside the pins. Run another cup of clear water after doing this to push out any debris that you may loosen up by doing this.
Over the past few years one of the hottest sensations in Coffee Brewing, has been the single cup brewing machines. One of the names at the top of the list of these brewing machines is the Keurig brand coffee brewer.
The Keurig customer service website has the answers to many of the questions that people have about their new machines. This Keurig website has the registration, warranty, user manuals, as well as cleaning and troubleshooting all in one place. Once you get there the site is very easy to navigate and you may find yourself reading therefor quite a while as you absorb all of the information that is contained there.
As you might expect there are problems that you may have that are not addressed there. The site obviously is maintained by Keurig and there are things that they do not address readily. However many of the basics are there and it is a very good place to start, especially with the cleaning and maintenance of your coffee brewer. In fact if you do the proper maintenance and cleaning on your coffee brewer regularly the chances of you having major problems will be greatly reduced.
To go to the Keurig customer service website click on the link below.
http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help
Hope it helped.
Jun 02, 2011 | Keurig B60 Coffee Maker
Keurig Platinum is clogged
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Mar 18, 2010 | Keurig Platinum B70 Coffee Maker
Water in Keurig single cup coffeemaker was very low--started it too soon & ran out; added water but still won't flow more than a drip or two
Nov 11, 2008 | Keurig B50 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
16 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
