Question about Dometic Heating & Cooling
Small replacement filter for Dometic 6204 Air Conditioner
SOURCE: Dometic Rooftop RV Air conditioner
why is our dometic roof top a/c on our boat draining water back into boat. is there a way to clean the drain?
Posted on May 30, 2008
  • 659 Answers
SOURCE: Compressor needs replacing
Good luck, I'm in the business and it's virtually impossible to find just the compressor for rooftop rv units. You might be able to get one through and RV dealer that sells parts as well. Also, contact dometic. Usually the only time a compressor is replaced is when the units are still in warranty. Let me add one more thing. Because of the price, it's more economical to replace the whole uint since most of these units are below $800 total price.
Posted on Mar 21, 2009
  • 68 Answers
SOURCE: Error code of E4 on Dometic HP air conditioner ??
16. SYSTEM RESET
a. Turn the ON/OFF switch to “OFF” position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to “ON”.
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection. Try this. This is for the five button thermostat. Did you check the dip switches to be sure the proper ones are turned on? I need to know which stat you have 4 or 5 button. I have trouble shooting for both.
If you notice reset needs to take place after a dip switch is turned on or off. The dip switches are on the circuit board. You need to drop the lower cover. the dip switches will read in this order #1 heat strip/ #2 zone2/#3zone3/ #4 zone4/#5 furnace/#6 differential/#7stag/#8 gen start. Check this out and be careful. Turn off the stat to change dip switches. On will be toward the description. If you don't have remote start gen set the dip should not be on. If you dont have a Zone 3 the dip should not be on, etc.
Any questions feel free to post back
Thank you for using fixya
Jerry
Posted on Mar 26, 2009
  • 34 Answers
SOURCE: Dometic Air conditioner model 57915-531 blows hot air
Have freon and compressor checked out, could also be bad capacitor
Posted on Aug 11, 2009
motor1258
  • 6674 Answers
SOURCE: Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
Posted on Jun 05, 2010
Dometic rooftop a/c compressor will not shut off. The only way to stop the compressor is to shut it off at the breaker. The fan and all other funtions operate properly from the thermostat. I tried...
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Oct 03, 2011 | Dometic 57915531 Air Conditioner
Not enough cold air out of dometic roof air outside temp 74 degrees
Air filter? #1 cause of air conditioning and heat pump problems. Filters are cheaper than repairs, a lot cheaper.
Mar 27, 2010 | Dometic Rooftop RV Air Conditioner
I just replaces the small capasitor the fan runs on Low and High when I kick the thermostat down it clicks and turips breaker Dometic 57915C
If it wasn't tripping the breaker prior to replacing the capacitor, I would check my wiring again........also look for wires that may have loosened or got "pinched" while servicing/reassembling.
Mar 17, 2010 | Dometic Rooftop RV Air Conditioner
We have a 2005 Country Coach Allure with 3 Dometic rooftop air conditioner/heat pumps. One of the units will come on start to cool then quickly turn to heat then cool then heat. What could the problem...
Hi; Sounds like a problem with the tstat or the defrost sensor. Also have these units been cleaned yearly. Also if the differential between heat and cool is small this will cause the unit to cool then heat due to the low differential at the tstat...alpharome416
Feb 23, 2010 | Dometic Rooftop RV Air Conditioner
Aug 11, 2009 | Heating & Cooling
Temp sensor
Look for little probe sticking out into return air duct area, beside controls. Usually visible when you take filters off. About 2-3" long and 3/16" in diameter, attached to small brass tube.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Quick Cool RV unit
Time to be serviced,could be a small leak and loosing freon, or low air flow due to dirty filter.,
Sep 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic duo therm a/c for rv
generally most R/v dealers should have those replacement parts they will have detailed diagrams that you can tell them exactly what you need
Aug 28, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
23 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
